Showing results forย
Search instead forย
Did you mean:ย
No ping between cisco C9300 and ICX-8200 switch
Mohammadsaeed
I have ICX-8200 switch link with cisco C9300 as trunk link but I can't ping between switches without make switch port native vlan 12 in cisco, and I don't want to use vlan 12 as native i want vlan 1
C9300 (port Gig1/0/1 ------> ICX-8200 (port 1/2/1)
here is my ICX8200 config:
vlan 1 by port
untagged ethe 1/2/1
spanning-tree 802-1w
vlan 12 name Network_Mgt by port
untagged ethe 1/2/1
ip route 0.0.0.0/0 10.25.60.100
fast port-span exclude ethe 1/2/1
hostname ICX8200-8P-200
ip multicast passive
ip tftp blocksize 8192
fdp run
interface management 1
interface ethernet 1/2/1
no cdp enable
spanning-tree 802-1w admin-edge-port
pvst-mode
interface ve 1
interface ve 12
ip address 10.25.61.135 255.255.254.0
interface ve 4000
Cisco Switch:
interface GigabitEthernet1/0/1
description *** Connected to ICX8200-8P ***
switchport trunk allowed vlan 1,9,12,14,22,131,132,202
switchport mode trunk
udld port aggressive
no vtp
spanning-tree portfast trunk
end
interface Vlan12
ip address 10.25.61.36 255.255.254.0
end
using these configuration no ping between cisco and ICX switch, but if i add this command under cisco switch:
switchport trunk native vlan 12
Then i can ping but I don't want to use vlan 12 as Native, i want vlan 1 only.
Any help please
5 REPLIES 5
From what I believe, it was a way to convey how the configuration attempted
Hence, based on that, the suggestions were shared.
But as mentioned, we would not be able to use 2 untagged vlans at the same time, as we do not use hybrid-ports that usually support 2 untagged vlans.
Hence, one of the two would need to be passed as tagged/trunk-allowed vlan. on either ends.
