05-28-2024 10:54 AM
The Support Document of Metro Ring Protocol Says..
"The member VLAN for a customer must contain the two ring interfaces and the interfaces for the customer. Since these interfaces are shared with the master VLAN, they must be tagged
if the Customer VLAN is 30
Can i use the the Below Commands ?
VLAN30
tag interface e 1/1/1 e 1/1/2 (Ring Interfaces)
untagged interface e 1/1/3 ( User PC)
05-29-2024 09:31 AM
Hi Chamilasw
Thank you for reaching us
You can use the below commands
Make sure the uplink or the tagged settings are same on both sides. The ports setting would need to match for the communication to happen between both the directly connected devices.
