07-21-2025 01:38 PM - edited 07-21-2025 01:43 PM
I am having an issue booting from the primary partition of my ICX7150
The following is a snippet of what happens when the primary partition begins to boot.
I can boot the secondary just fine by hitting 'b' and running the secondary partition.
I have tried following the steps to recover the partition via TFTP
Starting kernel ...
Mounting file system...
booting with 4.4 kernel
PLATFORM MN
dd cmd: UBI
Config partition mounted
Resource partition is mounted!!
eUSB Not mounted or detected
Processing packages from primary partition
New packages found, uninstalling old packages if any..
UBIFS error (ubi0:0 pid 717): ubifs_check_node: bad magic 0x6501831, expected 0x 6101831
UBIFS error (ubi0:0 pid 717): ubifs_check_node: bad node at LEB 86:754784
Not a node, first 24 bytes:
00000000: 31 18 50 06 f8 b7 48 db 04 23 18 00 00 00 00 00 a0 00 00 00 00 02 00 0 0 1.P...H..#..............
UBIFS error (ubi0:0 pid 717): ubifs_read_node: expected node type 0
UBIFS error (ubi0:0 pid 717): ubifs_iget: failed to read inode 6775, error -117
UBIFS error (ubi0:0 pid 717): ubifs_lookup: dead directory entry 'formparser.cpy thon-35.pyc', error -117
rm: can't stat '/.pkg/usr/lib/python3.7/site-packages/flask_packUBIFS error (ubi 0:0 pid 717): ubifs_check_node: bad CRC: calculated 0xc3babc1a, read 0x7907b52f
age/werkzeug/__pycache__/formparser.cpython-35.pyc': Structure nUBIFS error (ubi 0:0 pid 717): ubifs_check_node: bad node at LEB 86:754944
eeds cleaning
rm: can't remove '/.pkg/usr/lib/python3.7/site-pa magic 0x6101831
ckages/flask_package/werkzeug/__pycache__/utils.cpython-35.pyc': crc 0x7907b52f
Read-only file system
rm: can't remove '/.pkg/usr/lib/python3. node_type 0 (inode node)
7/site-packages/flask_package/werkzeug/__pycache__/routing.cpyth group_ty
