Inter-VRF-Routing-ICX7750
PC_JP
ICX(config)# vrf client1
ICX(config-vrf-client1)# rd 7750:1
ICX(config-vrf-client1)# address-family ipv4
ICX(config-vrf-client1-af)# exit
ICX(config)# vrf client2
ICX(config-vrf-client2)# rd 7750:2
ICX(config-vrf--client2)# address-family ipv4
ICX(config-vrf--client2-af)# exit
ICX(config)# vrf client3
ICX(config-vrf-client3)# rd 7750:3
ICX(config-vrf--client3)# address-family ipv4
ICX(config-vrf--client3-af)# exit
ICX(config)# vrf client4
ICX(config-vrf-client4)# rd 7750:4
ICX(config-vrf--client4)# address-family ipv4
ICX(config-vrf--client4-af)# exit
ICX(config)# vlan 550 name client1_vlan
ICX(config-vlan-550)#router-interface ve 550
ICX(config-vlan-550)#interface ve 550
ICX(config-vif-550)#vrf forwarding client1
ICX(config-vif-550)#ip address 192.168.150.1/24
ICX(config)# vlan 550 name client2_vlan
ICX(config-vlan-551)#router-interface ve 551
ICX(config-vlan-551)#interface ve 550
ICX(config-vif-551)#vrf forwarding client1
ICX(config-vif-551)#ip address 192.168.160.1/24
ICX(config)# vlan 1023 name client3_vlan
ICX(config-vlan-1023)#router-interface ve 1023
ICX(config-vif-1023)#vrf forwarding client3
ICX(config-vif-1023)#ip address 192.168.110.1/24
ICX(config)# vlan 1024 name client4_vlan
ICX(config-vlan-1024)#router-interface ve 1024
ICX(config-vif-1024)#vrf forwarding client3
ICX(config-vif-1024)#ip address 192.168.120.1/24
ICX(config)# ip route vrf client1 192.168.110.0/24 ve 1023
ICX(config)# ip route vrf client2 192.168.120.0/24 ve 1024
ICX(config)# ip route vrf client3 192.168.150.0/24 ve 550
ICX(config)# ip route vrf client4 192.168.160.0/24 ve 551
On checking,the vrf routes,i can see the routes
#show ip route vrf <vrf_name>
but when i check the ping for example
#ping vrf client1 192.168.110.1
#ping vrf client2 192.168.120.1
#ping vrf client3 192.168.150.1
#ping vrf client4 192.168.160.1
I am not receiving any ping...
is this way of inter-vrf-route from one one vrf to another vrf on the same switch
3 REPLIES 3
MariaC862
Hi!
Thank you for posting your query, please indicate the version on the switch. You can check that using #show version
Also, could you please try pinging with the source interface specified? #ping x.x.x.x source x.x.x.x
Check for any firewall rules or ACLs that might be blocking traffic between the VRFs.
Ensure that all interfaces associated with the VRFs are up and running. You can verify this with #show ip interface brief
Thanks.
Maria Cordoba
Sr. TSE | RICXI | RCNI
there is no any firewall settings and no ACL.
VRF is working properly and the sw version is 08.0.95pT203
va10462
Hi PC_JP,
I am running these tests in ICX 7550 running GZR10010g_cd6
For ping between vrf(Inter vrf routing), you need a gateway eg, firewall or router to route the traffic.
Check if the gateway device has any acl blocking it. Check the return path(route from gateway to switch).
I am testing with GZR10010g_cd6.bin on ICX 7550 and inter vrf routing is working fine without any issues.
please open a support case so we can formally investigate.
You can use below link to log a ticket:
Thanks,
Vivek
