12-09-2022 09:17 PM
Hello guys,
I have a ICX7450 L3 switch with SW: Version 08.0.90dT213 and it seems the switch doesn't reply to the snmp get V1 or v2c or v3. I was wondering if anyone experienced the same issue.
Thank you
12-12-2022 06:24 AM
What do you see in 'show snmp'? This will give you some statistics. You can also check 'show snmp server' to check status. Did you define community strings?
