05-22-2025 07:30 AM
I have a site with several ICX7150 switches. A few 48P, a few 24P and one C12P. They were previously running on SPS08095k and I wanted to upgrade to SPS08095r. I can currently “only” manage them via vSZ or remotely via SSH using VPN.
The network is simple: no LAGs, no stacks, nothing special, a simple tree structure, just a few VLANs. All the switches are new and were only installed two or three months ago.
So I initiated the upgrade for the entire switch group. This worked for 11 of the 13 switches on this site, but not for one 48P and the C12P. The status is “Failed” and under Failure Reason under Firmware History it says “Job timed out after 120 mins, please retry later.”
I've repeated the upgrade process for these two switches after a warm reboot but it didn't change. It takes like 20 to 25 min and the Failure Reason is still the same. While the C12P is at
I also tried HTTPS and uploaded the SPS08095rufi.bin to a webspace and tried the following:
SSH@icx7150#copy https flash A.B.C.D SPS08095rufi.bin primary port 443
SSH@icx7150#Feb 8 14:44:42:HTTP Request Failed for Request ID: 1. HTTP Connection Error...
This also does not work with the switches that have already been updated. So I think there might be another problem.
SCP and TFTP are out, as I am currently unable to set up a corresponding server.
What should I try next or could be the issue?
05-23-2025 05:36 AM
Is there high CPU or anything out of the ordinary on the cli? At this point I would recommend opening a formal case.
