02-15-2024 05:01 PM
Hello, We have Six ICX7150 SW Running Image Version: 08.0.90dT213.
Can you tell me what version is recommended, and can it be updated directly to the latest version, or are there some required versions in between?
Thank you.
02-15-2024 06:05 PM - edited 02-15-2024 06:06 PM
8095m or 8095n would be my recommendation at the moment. You can also look at this:
You can upgrade direct.
02-15-2024 08:49 PM - edited 02-15-2024 09:12 PM
Hi @BenBeck
Thanks for the response. We have downloaded the 8095m firmware. In the folder, I could see 2 files. Could you please check and share which file should we use for the upgrade. Attached screenshot for reference.Please ignore the VLC format
02-15-2024 11:58 PM - edited 02-16-2024 12:00 AM
Hi Adit,
In the screenshot, I can see one is SPR8095mufi and another is SPS8095mufi here SPR stands for routing image and SPS stands for switching image.
So it depend on what type firmware you are using earlier if you are using a router code use SPR and if you are using switch code use SPS. You can find this by using show version command on your existing setup.
Moving Forward If this issue is not resolved , Please log a ticket with the below link so that we will help you further.
I hope this information helps you
Please feel free to leave us a message if any concerns
02-18-2024 09:04 PM
This is the current version details. Could you please check and recommend which version should use for upgrade.
SSH@RSH-STH-SW-02>sh ver
UNIT 1: compiled on Sep 23 2019 at 00:00:25 labeled as SPR08090d
(32539748 bytes) from Secondary SPR08090d.bin (UFI)
SW: Version 08.0.90dT213
Compressed Secondary Boot Code size = 786944, Version:10.1.15T225 (mnz1011 5)
Compiled on Thu Jan 31 07:08:55 2019
HW: Stackable ICX7150-24-POE
UNIT 1: SL 1: ICX7150-24P-4X1G POE 24-port Management Module
Serial #:FEA3238R0FT
Software Package: ICX7150_BASE_L3_SOFT_PACKAGE
Current License: 4X1G
UNIT 1: SL 3: ICX7150-4X10GF 4-port 40G Module
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 23 hour(s) 25 minute(s) 47 second(s)
The system started at 00:03:50 GMT+00 Sat Jan 01 2000
