12-29-2023 01:54 PM
Just purchased as an upgrade for my home lab a pair of
12-31-2023 09:18 AM
Hi Penguinpages
Thank you for reaching us
Below are few details I could find from "FastIron 08.0.30 Layer 3 Routing Configuration Guide".
I have mentioned the link below about the guide I referred and those are the only options available, refer Page 45,44 and 46 and Run through topic "Changing the MTU"
I hope this helps
01-23-2024 08:57 AM
Thanks for respone.. but I don't think that applies to my version / code base of ICX
SSH@sw0-1(config-if-e1000-2/1/5)#sh version
Copyright (c) 1996-2016 Brocade Communications Systems, Inc. All rights reserved.
UNIT 2: compiled on Apr 23 2020 at 13:17:12 labeled as FCXR08030u
(10545591 bytes) from Primary FCXR08030u.bin
SW: Version 08.0.30uT7f3
UNIT 1: compiled on Apr 23 2020 at 13:17:12 labeled as FCXR08030u
Boot-Monitor Image size = 370695, Version:10.1.00T7f5 (grz10100)
HW: Stackable ICX6610-24-HPOE
UNIT 1: SL 1: ICX6610-24P POE 24-port Management Module
Serial #: 2ax5o2jk68e
License: ICX6610_ADV_ROUTER_SOFT_PACKAGE (LID: H4CKTH3PLN8)
P-ENGINE 0: type E02B, rev 01
UNIT 1: SL 2: ICX6610-QSFP 10-port 160G Module
UNIT 1: SL 3: ICX6610-8-port Dual Mode(SFP/SFP+) Module
UNIT 2: SL 1: ICX6610-24P POE 24-port Management Module
--More--, next page: Space, next line: Return key, quit: Control-c^C
SSH@sw0-1(config-if-e1000-2/1/5)#ip m
max-mroute Configure maximum multicast route (mroute)
mroute Configure static multicast route
multicast Set IGMP snooping globally
multicast-debug-mode Enable global multicast debug mode for all vrf
multicast-nonstop-routing Enable global multicast nonstop-routing support
for all vrf
multicast-routing Enable global support for Multicast routing and
IGMP
SSH@sw0-1(config-if-e1000-2/1/5)#ip manks for response.. but I don't think that applies to my version of ICX.
I kind of gave up .. disabled jumbo frames and had to adjust HCI stack to not require it.
