ICX6450-48p POE no longer working after power outage
Intropy
I had a sudden power outage, and after rebooting the switch is not supplying power on any configured ports. It is also failing to send data on one port.
I reenabled POE on the ports. I've gathered some info, but nothing about it suggested something wrong to me. Admin state is On while Oper State is Off.
SSH@brocade>show inline power
Power Capacity: Total is 740000 mWatts. Current Free is 740000 mWatts.
Power Allocations: Requests Honored 0 times
1/1/1 Off Off 0 0 n/a n/a 3 n/a
1/1/2 Off Off 0 0 n/a n/a 3 n/a
1/1/3 Off Off 0 0 n/a n/a 3 n/a
1/1/4 Off Off 0 0 n/a n/a 3 n/a
1/1/5 Off Off 0 0 n/a n/a 3 n/a
1/1/6 Off Off 0 0 n/a n/a 3 n/a
1/1/7 Off Off 0 0 n/a n/a 3 n/a
1/1/8 Off Off 0 0 n/a n/a 3 n/a
1/1/9 Off Off 0 0 n/a n/a 3 n/a
1/1/10 Off Off 0 0 n/a n/a 3 n/a
1/1/11 Off Off 0 0 n/a n/a 3 n/a
1/1/12 Off Off 0 0 n/a n/a 3 n/a
1/1/13 Off Off 0 0 n/a n/a 3 n/a
1/1/14 Off Off 0 0 n/a n/a 3 n/a
1/1/15 Off Off 0 0 n/a n/a 3 n/a
1/1/16 Off Off 0 0 n/a n/a 3 n/a
1/1/17 Off Off 0 0 n/a n/a 3 n/a
1/1/18 Off Off 0 0 n/a n/a 3 n/a
1/1/19 Off Off 0 0 n/a n/a 3 n/a
1/1/20 Off Off 0 0 n/a n/a 3 n/a
1/1/21 Off Off 0 0 n/a n/a 3 n/a
1/1/22 Off Off 0 0 n/a n/a 3 n/a
1/1/23 Off Off 0 0 n/a n/a 3 n/a
1/1/24 Off Off 0 0 n/a n/a 3 n/a
1/1/25 Off Off 0 0 n/a n/a 3 n/a
1/1/26 Off Off 0 0 n/a n/a 3 n/a
1/1/27 Off Off 0 0 n/a n/a 3 n/a
1/1/28 Off Off 0 0 n/a n/a 3 n/a
1/1/29 Off Off 0 0 n/a n/a 3 n/a
1/1/30 Off Off 0 0 n/a n/a 3 n/a
1/1/31 Off Off 0 0 n/a n/a 3 n/a
1/1/32 Off Off 0 0 n/a n/a 3 n/a
1/1/33 Off Off 0 0 n/a n/a 3 n/a
1/1/34 Off Off 0 0 n/a n/a 3 n/a
1/1/35 Off Off 0 0 n/a n/a 3 n/a
1/1/36 Off Off 0 0 n/a n/a 3 n/a
1/1/37 On Off 0 0 n/a n/a 2 n/a
1/1/38 On Off 0 0 n/a n/a 2 n/a
1/1/39 On Off 0 0 n/a n/a 2 n/a
1/1/40 On Off 0 0 n/a n/a 2 n/a
1/1/41 On Off 0 0 n/a n/a 2 n/a
1/1/42 On Off 0 0 n/a n/a 2 n/a
1/1/43 On Off 0 0 n/a n/a 2 n/a
1/1/44 On Off 0 0 n/a n/a 2 n/a
1/1/45 On Off 0 0 n/a n/a 2 n/a
1/1/46 On Off 0 0 n/a n/a 2 n/a
1/1/47 On Off 0 0 n/a n/a 2 n/a
1/1/48 On Off 0 0 n/a n/a 2 n/a
Total 0 0
SSH@brocade>show inline power detail
Power Supply Data On stack 1:
Power Supply Data:
Power Supply #1:
Max Curr: 13.7 Amps
Voltage: 54.0 Volts
Capacity: 740 Watts
power supply 2 is not present
power supply 3 is not present
POE Details Info. On Stack 1 :
General PoE Data:
Firmware
Version
02.1.0 Build 004
Cumulative Port State Data:
#Ports #Ports #Ports #Ports #Ports #Ports #Ports
Admin-On Admin-Off Oper-On Oper-Off Off-Denied Off-No-PD Off-Fault
Cumulative Port Power Data:
#Ports #Ports #Ports Power Power
Pri: 1 Pri: 2 Pri: 3 Consumption Allocation
1 ACCEPTED SOLUTION
Chandini
RUCKUS Team Member
Hi Intropy
Ack and Noted. You are right 6450 is end of life. You can log a support case to validate warranty and check if you can get a RMA for the device. Troubleshooting support would not be available if no contract but try to validate switch hardware warranty.
Team will help you with the details and accordingly proceed.
9 REPLIES 9
Chandini
RUCKUS Team Member
Hi Intropy
Thank you for for reaching us
Ack and Noted. I suppose the commands are not running since switches are on 8030u version. Since we are not seeing any error , it would be difficult to say if this is a hardware issue.
Try to move the PoE device on ports which show up "Off" . Enable PoE and note if the PoE is working on few ports and if it fails to work few ports or it is the same issue with all ports.
I suppose this could be a hardware failure if you notice few ports are working when same PoE device is connected and few don't on the same switch.
If you are looking for RMA please feel free to log a case with us using the below link
Intropy
I disabled POE on all ports, then I enabled it on a different set of four ports, 1/1/31-1/1/34. These were not in use, and I have never enabled POE on them in the past. They showed the same behavior as the original set of ports. They did not power any POE devices and showed up with admin state "on" and oper state "off".
Intropy
Would an RMA case be different from a support case? I opened a support ticket before posting in this forum, and  there I was told that "ICX6450 is now announced to be 'End of Support'" so they could not help.
Chandini
RUCKUS Team Member
Hi Intropy
Intropy
Thank you. I appreciate your help.
