07-19-2023 10:52 AM - edited 07-19-2023 10:59 AM
I am seeing issues with no matching SSH Key Exchange Algorithm (KEX) when attempting to SSH to/from an ICX with 9.0.10e and ICXs with 8.0.90k or 8.0.95g firmware. I turned on debug for ssh on both ICXs and what I found is the following....
ICX 8.0.90k SSH to ICX 9.0.10e and I get no matching key exchange method found. Their offer diffie-hellman-group14-sha1, diffie-hellman-group1-sha1
ICX 9.0.10e SSH to ICX 8.0.90k and I get SSH: KEX Algorithm no match found
I thought that FI 9.0.10e supports diffie-hellman-group14-sha1 by default?
The end result is that any non-9.0.10e ICXs can ssh to each other, and 9.0.10e ICXs can ssh to each other, but you cannot ssh between the versions because SSH KEX issue.
07-19-2023 11:50 AM
Hey Kenneth,
I believe this is expected due to upgraded SSH in 9010d and onward. I think you can enable EC (elliptical key pair) on both ends as a workaround. I am not in front of a CLI right this second, but it should be something like this:
conf t
crypto key gen ec (tab through this for syntax options)
07-19-2023 12:15 PM
I configured two ICXs with #crypto key generate ec label testkey (default size = 384). I still cannot negotiate session between the two ICXs, one with 9.0.10f and one with 8.0.90k. I have not done any debugging yet.
Can I have both an rsa and ec key pair at the same time?
07-19-2023 12:17 PM
You can. 'show ip ssh config' should confirm. Can you try removing the non-EC?
07-19-2023 12:26 PM
When I do "sh ip ssh config" I see two host keys (RSA 2048, ECDSA) with 9.0.10f but with 8.0.90k I see only one host key (RSA2048) even though I see "crypto key generate ec label testkey" in the running config. So, for 8.0.90k it looks like it can only have one host key. I don't want to delete the rsa key at the moment since this is operational switch. I may have to do further testing in a Lab unless you have other recommendations.
