09-07-2023 09:26 PM
After losing power, my ceiling WAPs stopped receiving power from the POE cable.
The internet is still feeding to the WAP units. I tested this by plugging the POE cable directly into my computer and the Internet works great. I have also tested the WAPs by plugging them in directly to a power source and they come back online and work great.
How do I get my switch unit to start pushing power to the WAP units again via the POE cable?
I have read through multiple troubleshooting posts nothing works
09-08-2023 04:33 AM
Hi Patty
Thank you for reaching us.
Check if you have access to switch using console . Below is the link that will help you to access switch using console
Once you are able login to the switch using CLI. Please execute the below command
The above command will help you understand if the power is delivered to the device connected on the port if not it will show the sate / error
Below are few reference links:
YouTube Video:
I hope this helps
09-08-2023 05:26 PM
AP's have internet but no power
09-08-2023 05:27 PM
black connection which is the only green light in 12 ports is internet coming from our internet modem/router
09-08-2023 05:28 PM
if we connect AP's directly to power source they light up
