ICX Switches software release versions
davefrag
Hello everyone,
I'm evaluating the software releases that are running on our ICX switches and trying to determine the date they were released and the version number and date of the most recent release of software for each.  Below is a list of ICX switches and the software versions running on each.
Model            RunningVersion       ReleaseDate       MostRecentVersion       ReleaseDate
ICX 7150       08.0.90jT211
ICX 7450       08.0.95T211
ICX 7750       08.0.95gT203
Thanks ahead of time for your responses.
3 REPLIES 3
BenBeck
Hey Dave,
You can find the release dates within the release notes for each respective release. Those are posted on the support portal.
https://support.ruckuswireless.com/documents?filter=108#sort=relevancy&f:@source=[Documentation]&f:@...]
I would currently recommend 8095J for those three models.
davefrag
Thanks for the advise.  Will the EOA and/or EOSL dates be included within these release notes as well for the previous versions?
Hey Dave,
No end of support date for those models as of now. I can say that the last supported code train for 7750 is 8095, while the last supported code train for 7150/7450 is 9010. Both of those code trains are still active.
