โ06-11-2024 08:33 PM
It appears we have a very basic ping command, even in version 9.0.10
Is there some other command ( I can't find) to perform source pings from a L3 enabled ICX ?
thanks
โ06-12-2024 06:25 AM - edited โ06-12-2024 06:25 AM
Hello @BsergentNZ ,
You can ping using a source address through virtual interfaces, including loopback interfaces .... etc , by utilizing a valid and active IP address on your switch.
Here is the Guide : https://docs.commscope.com/bundle/fastiron-08030-adminguide/page/GUID-39101781-07F5-4E13-BB2E-1D6E6E...
โ06-12-2024 06:44 PM
and here's the reference for 09.0.10 which you said you're using:
no idea if case 01631172 is also present on 09.0.10 , but that was a fun one ๐
โ06-13-2024 05:18 AM
Hello @inphobia ,
Thanks for the reference, based on my understanding of this issue, only code 10.0.10 was affected.
Tested using ICX7550-48F - Code GZR09010j_cd1 and not issues on this.
Best Regards
Fernando Vasquez
