01-22-2025 12:03 PM - edited 01-22-2025 12:04 PM
I have an ICX 7650-48F unit that is constantly rebooting.
I have attempted a soft reset which resulted in an indefinite initializing state (sys LED blinking green).
I have also attempted recovery procedure which resulted in no success.
Below I have pasted the boot monitoring list as it shows a failure in HW init. Is this unit in need of an RMA? or was there a step I missed in attempting to recover this unit?
61580116 bytes read in 505 ms (116.3 MiB/s)
## Loading kernel from FIT Image at 90000200 ...
Using 'conf@1' configuration
Trying 'kernel@1' kernel subimage
Description: Linux for ICX7650/ICX7850
Created: 2020-03-16 3:23:46 UTC
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x900002d8
Data Size: 3459243 Bytes = 3.3 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x80080000
Entry Point: 0x80080000
Hash algo: crc32
Hash value: 1a473a0f
Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 90000200 ...
Trying 'ramdisk@1' ramdisk subimage
Description: Ramdisk -rootfs
Type: RAMDisk Image
Data Start: 0x90359b34
Data Size: 58045929 Bytes = 55.4 MiB
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: f76d6abf
## Loading fdt from FIT Image at 90000200 ...
Trying 'fdt@1' fdt subimage
Description: ICX7650.dtb
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x9034cc5c
Data Size: 27517 Bytes = 26.9 KiB
Hash algo: crc32
Hash value: fd8efcc8
Loading fdt from 0x9034cc5c to 0x81200000
Booting using the fdt blob at 0x81200000
Uncompressing Kernel Image ... OK
reserving fdt memory region: addr=81000000 size=200000
reserving fdt memory region: addr=e0000000 size=1000000
Loading Ramdisk to fb38c000, end feae75e9 ... OK
Using Device Tree in place at 0000000081200000, end 0000000081209b7c
Starting kernel ...
ssp-pl022 66180000.ssp: probe: no chip select defined
ssp-pl022 66190000.ssp: probe: no chip select defined
phy-bcm-ns2-sata 67004000.sata_phy: Will limit CDR integral to +-149 (about 4544ppm)
iproc-pcie 20020000.pcie: HOT-PLUG on bus:(null):1:313
iproc-pcie 50020000.pcie: HOT-PLUG on bus:(null):1:337
ahci 663f2000.ahci: can't get clock
iproc_nand 66460000.nand: timeout waiting for command 255 (9)
iproc_nand 66460000.nand: irq status 00000000, intfc status 00000000
iproc_nand 66460000.nand: timeout waiting for command 144 (7)
hub 1-0:1.0: config failed, hub doesn't have any ports! (err -19)
hub 3-0:1.0: config failed, hub doesn't have any ports! (err -19)
/hs_noc/usb@66480000: arguments longer than property
/hs_noc/usb@664a0000: arguments longer than property
/hs_noc/usb@0x664c0000: arguments longer than property
/hs_noc/usb@66480800: arguments longer than property
hub 5-0:1.0: over-current condition on port 1
/hs_noc/usb@664a0800: arguments longer than property
/hs_noc/usb@0x664c0800: arguments longer than property
iproc-udc 664e0000.usbd_udc_dwc: couldn't get extcon device
sdhci-iproc 66420000.sdhci: vqmmc not available, disable HS200 cap.
sdhci-iproc 66430000.sdhci: invalid resource
sdhci-iproc 66430000.sdhci: vqmmc not available, disable HS200 cap.
hub 8-0:1.0: over-current condition
sd 2:0:0:0: [sdb] No Caching mode page found
sd 2:0:0:0: [sdb] Assuming drive cache: write through
of_dma_request_slave_channel: dma-names property of node '/apb/serial@66130000' missing or empty
INIT: version 2.88 booting
INIT: Entering runlevel: 3
Starting mdev...
Starting irqbalance: OK
Starting SP805 watchdog...
System time was Thu Jan 1 00:32:16 UTC 1970.
Setting the System Clock using the Hardware Clock as reference...
System Clock set. System local time is now Thu Jan 1 00:32:16 UTC 1970.
Initializing random number generator... done.
Starting system message bus: done
Starting network: OK
Starting HPA's tftpd: done
Starting fw_downloader: OK
fw_downloader started
Mounting
file system...
### FS Management... ###
Creating /dev/sda devices
Done
Partition Present BitMap: 7
Running FS Check, followed by Partition Mount ...
e2fsck 1.43.4 (31-Jan-2017)
/dev/sda1: clean, 13/131072 files, 147258/523264 blocks
fsck for boot partition complete, result (Code: 0):
No FS Error
/dev/sda2: recovering journal
/dev/sda2: clean, 18/32768 files, 6263/131072 blocks
fsck for opt partition complete, result (Code: 0):
No FS Error
/dev/sda3: clean, 108/196608 files, 66498/786176 blocks
fsck for config partition complete, result (Code: 0):
No FS Error
Partition Mount xBitMap: 0
Partitions successfully mounted
### FS Management Complete ###
Checking Boot partition...
Done
1 external USB Drive(s)/Partition(s) Mounted
Processing packages from primary partition
Incompatible version of booted application and packages stored iSoftlockup time is given as 15 x 2 secs
gzip fixup getting applied/
PCIe Fixup is getting applied.
setpci: Warning: No devices selected for "4.w=0x4001".
Stopping Fw_downloader:OK
SKU TYPE 48F
BCM82756 is programmed to download the firmware over MDIO already.!!
Starting TPM Infra
addgroup: group 'tss' in use
Group tss and User tss created
kernel.hostname = localhost
hostname set to localhost
Starting TCSD Daemon
TCSD Up and Running
Creating TUN device
ethaddr: c0:c5:20:83:b4:d9
applying netdev fixups.
net.core.netdev_budget = 50
net.core.netdev_max_backlog = 2000
Enabling time stamp.
Installing crashkernel infra
primary image found. copying dts and os image from it.
/tmp/rootfs
Done!!
Starting the FastIron.
softlockup enabled on bootup.
INTR: Interrupt thread created ...
I2C_CLIENT: PSU Write failed @offset 28
Softlockup Module Init
PCI_CORE: rv 0 dev->mapped_address[0]= f6294000 , &p=0xcaed258
CLIENT_BINDER: No host found for client spi-mtd: host_name
CLIENT_CORE: I2C device database init
I2C_CORE: --> SG <-- no driver found for bus0 devtpm
CPLD_CORE: Platform_ID 66, sku-name 48F Non-POE
CPLD_CORE: HW Revision Type : 'PVT'
CPLD_CORE: PCB REV : 'V1'
WARNING: TSC frequency estimated Based on Monotonic Clock
TSC frequency is ~25001KHz
MEMORY: MEMORY Initialized
PCI_CORE: Probing all PCI Devices...
PCI_CORE: PCI device 0002:01:00.0
PCI_CORE: probe driver: 1657:20 es4651bfx_fpga
PCI_CORE: Cannot create /dev/uio0
PCI_CORE: uio number 0
PCI_CORE: UIO RESOURCE allocation Successfull
PCI_CORE: Physical 8000000 , Virtual 0xf6294000, size=200000
PCI_CORE: rv 0 dev->mapped_address[1]= f5094000 , &p=0xcaed25c
PCI_CORE: Physical 8200000 , Virtual 0xf5094000, size=200000
Library ==> Load Address
libc-2.24.so ==> 0xf6c94000
libgcc_s.so.1 ==> 0xf6d83000
libsilpi.so ==> 0xf6dad000
libplatform.so ==> 0xf6e2d000
libm-2.24.so ==> 0xf707b000
libpthread-2.24.so ==> 0xf7111000
libdl-2.24.so ==> 0xf7135000
librt-2.24.so ==> 0xf7148000
ld-linux.so.3 ==> 0xf715e000
FIPS Disabled:PORT NOT DISABLED
GENERIC: platform type 102
GENERIC: warm_mem 0xf5294000, size 86a, sil_get_warm_mem_pointer=0xf5294000,
GENERIC: warm_mem 0xf5294000, size 86c, sil_get_warm_mem_pointer=0xf529486c,
!!!!All CPLDS and FPGAs are up-to-date. No Update required !!
DDR_ECC: DDR ECC Check is enabled.
GENERIC: Signature: ca95 Base MAC: c0:c5:20:83:b4:9c
GENERIC:
Platform ID 102 [48F Non-POE] [fes_type= 130 ]
HW Revision 'PVT'
MAINBOARD FW:
Installed Version : 04.0A
CPLD0:
Installed Version : 02.08
CPLD1:
Installed Version : 03.01
GENERIC:
Loaded Image TNR08092b from Pri Built on (UTC): Mon Mar 16 03:23:52 2020
GENERIC: Enabling Console Logging
Applying factory defaults..
INFO: startup config data is not available, try to read from backup
INFO: startup config data in the backup area is not available
GENERIC: warm_mem 0xf529486c, size 39801c, sil_get_warm_mem_pointer=0xf529486c,
GENERIC: warm_mem 0xf529486c, size 39801c, sil_get_warm_mem_pointer=0xf562c888,
Hotplugger Daemon Initialized ..
set_board_level: gi_board_type = 130DMA pool size: 134217728
PHY Reset De-asserted
SOC unit 0 attached to PCI device BCM56568_B0
0:bcmi_xgs5_bfd_init: uKernel BFD application not available
Reseting PHY 0x0...
Retrying FW download on MIURA BCM82756 0x0
Reseting PHY 0x0...
Failed to release semaphore miura (handle 0xe0d00540), count 1, itr 0, error 1
stack: 0008370c 00083808 f6db6d2c 02dc21d0 001682a0 041789d8 f3bfeb04
Downloading firmware using MDIO. Will write to EEPROM if present
Reseting PHY 0x0...
MDIO download or writing firmware to EEPROM failed for 0x0
Failed to initialize Module 1 BCM82756 ports
Failed to initialize standalone PHYs. Aborting...
FATAL ERROR: Failed in HW init hence rebooting
8.5: Halt and reboot
Copying Hmon log files to flash..
Done
Copying SZ log files to flash..
Done
Copy RAMFS console log file to flash before we shutdown
Copy RAMFS fitrace error log file to flash before we shutdown
PCI-FPGA EP found, disabling FPGA interrupts
Unmounting external USB
Unmounting Boot partition
Unmounting Opt partition
Unmounting Config partition
Unbinding Drivers..
unbind done.
The system is going down NOW!
[ 70.229069] SysRq : Resetting
[ 70.286492] Requesting WARM Boot.
[ 70.327317] send DDR self-refresh command to M0
NOTICE: IHOST: Broadcom BCM58712 B0
NOTICE: IHOST: Setting Core Frequency to 2000
NOTICE: Booting Trusted Firmware
NOTICE: BL1: Built : 01:08:50, Oct 9 2019
NOTICE: BL1: Booting BL2
NOTICE: BL2: Built : 01:08:51, Oct 9 2019
NOTICE: Starting DDR bring-up for part "mt40a1g8" at 2132MHz and datawidth of 72bits ...
NOTICE: Warm Boot --> Skip DRAM Initialization
WARNING: DRAM, ECC errors detected on initialization.
NOTICE: DRAM tuning and initialization done!
WARNING: Failed to access image 'bl32.bin' (-1)
WARNING: Failed to load BL3-2 (-1)
NOTICE: BL1: Booting BL3-1
NOTICE: BL3-1: Built : 01:08:51, Oct 9 2019
ERROR: Error initializing runtime service tspd_fast
Ruckus Networks Bootloader: 10.1.17T235 (Oct 09 2019 - 01:08:48 -0700)
DRAM:
4 GiB
I2C: ready
Booting from Primay Flash
Check the firmware upgrade ... done.
In: serial
Out: serial
Err: serial
Enabling onboard SATA host
set up port 0
set up port 1
ahci_host_init: SATA link 0 ok.
AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq stag clo pmp fbss slum part
scanning bus for devices...
S/N: A46207170D8901807006
Firmware version: SBFM01.0
Product model number: SATA SSD
Capablity: 31277232 sectors
Device 0: (0:0) Vendor: SATA Prod.: SSD Rev: SBFM
Type: Hard Disk
Capacity: 15272.0 MiB = 14.9 GiB (31277232 x 512)
Found 1 device(s).
Net: e1000: c0:c5:20:83:b4:d9
1 e1000 interfaces found
done
e1000#0
Applying IDM Fixups...
SF: 512 bytes @ 0x17fe00 Read: OK
SKU Type : ICX7650-48F
CPU CPLD Revision: 02.07
Boot Loader Flash: Primary
FI Image to Boot : Primary
Thank you,
Joe J
01-22-2025 12:22 PM
Did anything trigger this? It may be worth trying to recover to 8080f. If you have support, I would recommend opening a case and someone can work with you live.
01-22-2025 12:30 PM
I was not here for the installation of the unit, just here for the scripting. Initially I noticed when I tried to terminal into the unit it kept kicking me out of puTTy and rebooting so I attempted to soft reset.
01-22-2025 12:59 PM
Unfortunately recovering to 8080f did not resolve the issue.
Here is the updated Boot message.
ICX7650-Boot> reset
resetting ...
NOTICE: BL1: Built : 04:59:51, Nov 15 2018
NOTICE: BL2: Built : 04:59:52, Nov 15 2018
NOTICE: BL3-1: Built : 04:59:52, Nov 15 2018
Bootloader: 10.1.14T235 (Nov 15 2018 - 04:59:47 -0800)
DRAM:
4 GiB
I2C: ready
Booting from Secondary Flash
In: serial
Out: serial
Err: serial
set up port 0
set up port 1
ahci_host_init: SATA link 1 timeout.
Type: Hard Disk
ahci_device_prep_command: No Link on port 1!
ata_scsiop_inquiry: SCSI inquiry command failure.
scsi_exec: SCSI command 0x12 ret errno -5
Found 1 device(s).
SCSI: ahci_host_init: SATA link 1 timeout.
Type: Hard Disk
Found 1 device(s).
done
e1000#0
CPU CPLD Revision: 0x2.0x7
Boot Loader Flash: Secondary
56877680 bytes read in 455 ms (119.2 MiB/s)
Description: ICX7650 Linux
Created: 2020-04-07 5:48:21 UTC
Type: Kernel Image
Data Start: 0x900002cc
Data Size: 3287570 Bytes = 3.1 MiB
OS: Linux
Hash algo: crc32
Hash value: 55151a44
Type: RAMDisk Image
Data Start: 0x90329a04
Data Size: 53540539 Bytes = 51.1 MiB
OS: Linux
Hash algo: crc32
Hash value: 65b80873
Data Start: 0x90322db8
Hash algo: crc32
Loading fdt from 0x90322db8 to 0x81200000
Loading Ramdisk to fb7dc000, end feaeb6bb ... OK
Starting kernel ...
Starting syslog-ng daemon: OK
Starting mdev...
System time was Thu Jan 1 00:05:26 UTC 1970.
System Clock set. System local time is now Thu Jan 1 00:05:26 UTC 1970.
Starting telnetd: OK
=========Softlockup time is given as 15 x 2 secs
Stopping Fw_downloader:killall: fw_downloader: no process killed
Starting fw_downloader: iproc-udc 664e0000.usbd_udc_dwc: couldn't get extcon device
OK
SKU TYPE 48F
Done
/dev/sda1: clean, 13/131072 files, 142648/523264 blocks
No FS Error
No FS Error
/dev/sda3: recovering journal
/dev/sda3: clean, 106/196608 files, 66496/786176 blocks
No FS Error
no block device found
Starting TPM Infra
TCSD Up and Running
Creating TUN device
/etc/init.sh: line 1118: ulimit: open files: cannot modify limit: Operation not permitted
/tmp/rootfs
Done!!
PCI_CORE: rv 0 dev->mapped_address[0]= f65c1000 , &p=0x26174228
I2C_CORE: no driver found for bus0 devtpm
PCI_CORE: Physical 8000000 , Virtual 0xf65c1000, size=200000
PCI_CORE: rv 0 dev->mapped_address[1]= f53c1000 , &p=0x2617422c
PCI_CORE: Physical 8200000 , Virtual 0xf53c1000, size=200000
libc-2.24.so ==> 0xf6fc1000
libgcc_s.so.1 ==> 0xf70b0000
libplatform.so ==> 0xf70da000
libsilipc.so ==> 0xf7387000
libm-2.24.so ==> 0xf7395000
libpthread-2.24.so ==> 0xf742b000
libdl-2.24.so ==> 0xf744f000
librt-2.24.so ==> 0xf7462000
ld-linux.so.3 ==> 0xf7478000
GENERIC: warm_mem 0xf55c1000, size 86a, sil_get_warm_mem_pointer=0xf55c1000,
GENERIC: warm_mem 0xf55c1000, size 86c, sil_get_warm_mem_pointer=0xf55c186c,
GENERIC:
HW Revision 'PVT'
MAINBOARD FW:
CPLD0:
CPLD1:
GENERIC:
Loaded Image TNR08080f from Pri Built on (UTC): Tue Apr 7 05:48:25 2020
flash_file=0.
GENERIC: warm_mem 0xf55c186c, size 398004, sil_get_warm_mem_pointer=0xf55c186c,
GENERIC: warm_mem 0xf55c186c, size 398004, sil_get_warm_mem_pointer=0xf5959870,
External USB disk is not mounted or plugged in.
Reseting PHY 0x0...
Reseting PHY 0x0...
Reseting PHY 0x0...
T=10.5: Halt and reboot
Unbinding Drivers..
unbind done.
[ 71.589369] SysRq : Resetting
[ 71.644076] Requesting WARM Boot.
[ 71.684900] send DDR self-refresh command to M0
DRAM:
4 GiB
I2C: ready
In: serial
Out: serial
Err: serial
set up port 0
set up port 1
Type: Hard Disk
Found 1 device(s).
Type: Hard Disk
Found 1 device(s).
done
e1000#0
01-22-2025 01:15 PM
It's not looking promising in my opinion. It might be an RMA. I'd open a case if you have support.
