05-22-2021 04:18 PM
I've been trying to enable web management on an ICX7550-48ZP without any luck.
At best, when web-management is enabled for HTTP I get a web page with just the message "Web-management support is not available for this device". If I enable web-management over HTTPS then I get a connection closed instead of a connection refused with HTTPS disabled.
I've flashed the latest FastIron 08.0.95d and did a `erase system factory-default` after the update. No luck, same behavior.
I've tried with the out-of-band management port, in-band ports, and vlans with and without management-vlan enabled. No luck, same behavior.
The ICX7550 switches are advertised as having web management capabilities. The docs seem to imply they are capable. But it does not work.
USB console, telnet, and unleashed management work fine for what it's worth...
Am I missing something? Is there some undocumented special requirement to get web management working on an ICX 7550 switch?
05-22-2021 06:09 PM
Hi Louis,
I hope you are doing Great!!! Sorry web management is not supported in 8095x code.
I looked thru the web management guide page 11 https://ruckus-support.s3.amazonaws.com/private/documents/3462/fastiron-08095-webguide.pdf?AWSAccess...
Best Regards
Hashim
08-13-2024 05:22 AM
Hey BTK,
We generally recommend the most mature, active code stream. That is why the recommendation is still formally 8095n as of this writing. You can certainly use the latest 9010 or 10010 patch if it has features that you need. Hope this helps.
