05-06-2022 08:13 AM
When I try to access the switch the login screen flashes for a second and then I get a white screen that says "Server Error. Will be fixed in a few minutes."
Tried different browsers on different computers, not a cache issue.
05-06-2022 09:40 AM
Groovy, missed that one.
06-29-2022 05:22 AM
Hallo,
Did you get an answer? I'm having the same problem
06-30-2022 10:17 AM
I had an open case on this in which they confirmed it was an issue. While I was waiting for a solution from them I tried 9.10c and the issue seams to have been resolved in that version.
