ICX 7250 updated to 9.10b no web access
network_adminis
When I try to access  the switch the login screen flashes for a second and then I get a white screen that says "Server Error. Will be fixed in a few minutes."
Tried different browsers on different computers, not a cache issue.
7 REPLIES 7
Groovy, missed that one.
fundi
Hallo,
Did you get an answer? I'm having the same problem
I had an open case on this in which they confirmed it was an issue. While I was waiting for a solution from them I tried 9.10c and the issue seams to have been resolved in that version.
