05-24-2024 10:17 AM - edited 05-24-2024 12:17 PM
Hello, I'm trying to monitor my switch's CPU load, memory util, and temperature through a third party network monitoring tool (PRTG). I have been looking everywhere for the snmp OIDs to do so but can't find them anywhere. My switch's version is 08.0.95mT211.
05-27-2024 03:35 AM
Hi Assiamour_
Thank you for reaching us
You can refer the below link for the OID's you are looking for.
05-27-2024 04:35 AM - edited 05-27-2024 04:37 AM
I've tried those and they do not work. The MIB doesn't have the OID's for the cpu load or memory util and the OID's from your post return an error when trying to set up sensors through PRTG.
05-27-2024 09:32 PM - edited 05-27-2024 09:33 PM
not running 8.x but
FOUNDRY-SN-AGENT-MIB::snAgImgVer.0 = STRING: "10.0.10cT233"
FOUNDRY-SN-AGENT-MIB::snAgFlashImgVer.0 = STRING: "10.0.10cT233"
and still need to add it to prtg (using that as well), but for cpu this should work:
FOUNDRY-SN-AGENT-MIB::snAgGblCpuUtil1SecAvg.0 = Gauge32: 2
FOUNDRY-SN-AGENT-MIB::snAgGblCpuUtil5SecAvg.0 = Gauge32: 2
FOUNDRY-SN-AGENT-MIB::snAgGblCpuUtil1MinAvg.0 = Gauge32: 2
memory:
FOUNDRY-SN-AGENT-MIB::snAgGblDynMemUtil.0 = Gauge32: 28
FOUNDRY-SN-AGENT-MIB::snAgGblDynMemTotal.0 = Gauge32: 4099227648
FOUNDRY-SN-AGENT-MIB::snAgGblDynMemFree.0 = Gauge32: 2946719744
temperature:
FOUNDRY-SN-AGENT-MIB::snChasActualTemperature.0 = INTEGER: 54
FOUNDRY-SN-AGENT-MIB::snChasWarningTemperature.0 = INTEGER: 118
FOUNDRY-SN-AGENT-MIB::snChasShutdownTemperature.0 = INTEGER: 124
FOUNDRY-SN-AGENT-MIB::snChasEnableTempWarnTrap.0 = INTEGER: enabled(1)
FOUNDRY-SN-AGENT-MIB::snChasGlobalIgnoreShutdownTemperature.0 = INTEGER: disabled(0)
FOUNDRY-SN-AGENT-MIB::snChasUnitActualTemperature.1 = INTEGER: 54
FOUNDRY-SN-AGENT-MIB::snChasUnitWarningTemperature.1 = INTEGER: 118
FOUNDRY-SN-AGENT-MIB::snChasUnitShutdownTemperature.1 = INTEGER: 124
FOUNDRY-SN-AGENT-MIB::snChasUnitIgnoreShutdownTemperature.1 = INTEGER: disabled(0)
FOUNDRY-SN-AGENT-MIB::snAgentTempSensorDescr.1.1 = STRING: "Sensor 1 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTempSensorDescr.1.2 = STRING: "Sensor 2 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTempSensorDescr.1.3 = STRING: "Sensor 3 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTempSensorDescr.1.4 = STRING: "Sensor 4 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTempSensorDescr.1.5 = STRING: "Sensor 5 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTempSensorDescr.1.6 = STRING: "Sensor 6 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTempSensorDescr.1.7 = STRING: "Sensor 7 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTempSensorDescr.1.8 = STRING: "Sensor 8 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTempValue.1.1 = INTEGER: 49
FOUNDRY-SN-AGENT-MIB::snAgentTempValue.1.2 = INTEGER: 59
FOUNDRY-SN-AGENT-MIB::snAgentTempValue.1.3 = INTEGER: 72
FOUNDRY-SN-AGENT-MIB::snAgentTempValue.1.4 = INTEGER: 54
FOUNDRY-SN-AGENT-MIB::snAgentTempValue.1.5 = INTEGER: 58
FOUNDRY-SN-AGENT-MIB::snAgentTempValue.1.6 = INTEGER: 54
FOUNDRY-SN-AGENT-MIB::snAgentTempValue.1.7 = INTEGER: 59
FOUNDRY-SN-AGENT-MIB::snAgentTempValue.1.8 = INTEGER: 103
FOUNDRY-SN-AGENT-MIB::snAgentTemp2SensorDescr.1.1.1 = STRING: "Sensor 1 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTemp2SensorDescr.1.1.2 = STRING: "Sensor 2 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTemp2SensorDescr.1.1.3 = STRING: "Sensor 3 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTemp2SensorDescr.1.1.4 = STRING: "Sensor 4 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTemp2SensorDescr.1.1.5 = STRING: "Sensor 5 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTemp2SensorDescr.1.1.6 = STRING: "Sensor 6 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTemp2SensorDescr.1.1.7 = STRING: "Sensor 7 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTemp2SensorDescr.1.1.8 = STRING: "Sensor 8 Temperature"
FOUNDRY-SN-AGENT-MIB::snAgentTemp2Value.1.1.1 = INTEGER: 49
FOUNDRY-SN-AGENT-MIB::snAgentTemp2Value.1.1.2 = INTEGER: 59
FOUNDRY-SN-AGENT-MIB::snAgentTemp2Value.1.1.3 = INTEGER: 72
FOUNDRY-SN-AGENT-MIB::snAgentTemp2Value.1.1.4 = INTEGER: 54
FOUNDRY-SN-AGENT-MIB::snAgentTemp2Value.1.1.5 = INTEGER: 58
FOUNDRY-SN-AGENT-MIB::snAgentTemp2Value.1.1.6 = INTEGER: 54
FOUNDRY-SN-AGENT-MIB::snAgentTemp2Value.1.1.7 = INTEGER: 59
FOUNDRY-SN-AGENT-MIB::snAgentTemp2Value.1.1.8 = INTEGER: 103
FOUNDRY-SN-AGENT-MIB::snAgentTempThreshold2LowValue.1.1 = INTEGER: 34
FOUNDRY-SN-AGENT-MIB::snAgentTempThreshold2HighValue.1.1 = INTEGER: 42
FOUNDRY-SN-AGENT-MIB::snAgentTempThreshold2ShutdownValue.1.1 = INTEGER: 62
05-27-2024 09:39 PM - edited 05-27-2024 09:41 PM
you'll most likely want to use "Absolute (unsigned integer)" in prtg for the custom mib tables
https://gitlab.com/PRTG/Device-Templates/Brocade could be an option, but if it's just for mem/cpu/temp a custom table should be pretty easy to make.
