ICX 7150 -> fanless or no fanless ?
i installed an ICX 7150 48P, and soon as he booted, there is a "panic fan noise, and never stopped.
sh ver -> 08.07.70bT211
i only have the choice to use the "chassis fanless mode" commande line to stopped the noise.
it's weird ! and the device is quite warm, below the warning limit of course, but warm.
and if fan are unable, the noise is too uncomfortable for users.
is there a fix ? is this an firmware issue ?
any idea will help,
thanks,
5 REPLIES 5
Hello !
finally i updated the firmware (manifest.txt) from 08.0.70c to 08.0.80b and it fixed the fan issue.
after the relaod, one minute middle level fan noise, then lower level.
thanks all for your support,
