07-07-2025 03:58 PM
Hi!
I wanted to get an older long time not used switch ICX-7150-C12P back working but it doesn't boot the correct way.
Tried to write a new primary image as described here:
https://community.ruckuswireless.com/t5/ICX-Switches/Unable-to-boot-image-to-Ruckus-ICX-7150/m-p/141...
Version: SPS09010j_cd8ufi.bin
Flash looked good (see second code tag), but I'm stuck at the same position.
Any ideas?
Thank you!
After flash (same as before):
Ruckus Networks Bootloader: 10.1.27T225 (Feb 06 2025 - 20:30:11 -0800)
Booted from partition 1
DRAM: Validate Shmoo parameters stored in flash ..... OK
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
Crashkernel Disabled
device 0 offset 0xbfe00, size 0x200
device 0 offset 0x0, size 0xc0000
Firmware Integrity Test: Uboot Checksum Verification: PASS
bootdelay: ===
Booting image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
33554432 bytes read: OK
Firmware Integrity Test: Image Checksum Verification: PASS
## Loading kernel from FIT Image at 70000200 ...
Using 'conf@1' configuration
Trying 'kernel@2' kernel subimage
Description: Ruckus Linux MN VER=09.0.10j_cd8
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x702cdcc8
Data Size: 2914846 Bytes = 2.8 MiB
Architecture: ARM
OS: Linux
Load Address: 0x61008000
Entry Point: 0x61008000
Hash algo: crc32
Hash value: 6bf0683d
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: crc32
Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 70000200 ...
Trying 'ramdisk@1' ramdisk subimage
Description: Ramdisk -rootfs
Type: RAMDisk Image
Data Start: 0x7059c0dc
Data Size: 23392654 Bytes = 22.3 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: dd455f3b
## Loading fdt from FIT Image at 70000200 ...
Trying 'fdt@3' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x70599e44
Data Size: 8671 Bytes = 8.5 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 11c2cafc
Loading fdt from 0x70599e44 to 0x65008000
Booting using the fdt blob at 0x65008000
Uncompressing Kernel Image ... OK
Using Device Tree in place at 65008000, end 6500d1de
Starting kernel ...
Mounting file system...
booting with 4.4 kernel
PLATFORM MN
dd cmd: UBI
Config partition mounted
Resource partition is mounted!!
eUSB Not mounted or detected
Successfully read the SKU Reg, the value is: 0xff
dma_mem_base: 0x96000000, dma_mem_len: 0x4000000, warm_mem_base: 0x9f500000, warm_mem_len: 0xb00000
Please download UFI image to install packages
Package installation is incomplete, related functionalities may not be available
Cannot boot FastIron application due to package installation failure
starting console application
server-execvp: python3: No such file or directory
OS>Flash output:
Load addr=0x70000000
Change GMAC speed to 1000MB
Using bcm_xgs_gmac-0 device
TFTP from server 192.168.1.2; our IP address is 192.168.1.1
Filename 'SPS09010j_cd8ufi.bin'.
Load address: 0x70000000
Loading: #################################################################
1.8 MiB/s
done
Bytes transferred = 91890919 (57a24e7 hex)
Copying U-Boot image (mnz10127.bin) to Primary flash
sf erase 0x0 0xc0000
sf write 0x71cc0f34 0x0 0xc0000
U-Boot update Done.
Copying FI image (SPS09010j_cd8.bin) to Primary flash
img_sz=0x1c00000 block_count = 0x1c
NAND erase.spread: device 0 offset 0x0, size 0x1c00000
Erasing at 0x1b00000 -- 100% complete.
OK
NAND write: device 0 offset 0x0, size 0x1c00000
29360128 bytes written: OK
FI-image update Done.
TFTP to Flash Done.
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot>boot_primary
U-Boot on the primary partition is updated.
Reset the system to boot from the primary partition.
resetting ...
using GPIO[7] to reset
