07-14-2020 08:40 AM
Booting image from Secondary
NAND read: device 0 offset 0x4000000, size 0x2000000
Skipping bad block 0x05a00000
Skipping bad block 0x05b00000
33554432 bytes read: OK
## Loading kernel from FIT Image at 70000200 ...
Using 'conf@1' configuration
Trying 'kernel@2' kernel subimage
Description: Ruckus Linux MN VER=08.0.90e
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x7024fa00
Data Size: 2401142 Bytes = 2.3 MiB
Architecture: ARM
OS: Linux
Load Address: 0x61008000
Entry Point: 0x61008000
Hash algo: crc32
Hash value: 8399a11a
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: crc32
Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 70000200 ...
Trying 'ramdisk@1' ramdisk subimage
Description: Ramdisk -rootfs
Type: RAMDisk Image
Data Start: 0x704a072c
Data Size: 23816895 Bytes = 22.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: e786d75c
## Loading fdt from FIT Image at 70000200 ...
Trying 'fdt@3' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x7049e4d4
Data Size: 8607 Bytes = 8.4 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 6fc9a37b
Loading fdt from 0x7049e4d4 to 0x65008000
Booting using the fdt blob at 0x65008000
Uncompressing Kernel Image ... OK
Using Device Tree in place at 65008000, end 6500d19e
Starting kernel ...
Mounting file system...
booting with 4.4 kernel
PLATFORM MN
dd cmd: UBI
Config partition mounted
Resource partition is mounted!!
Please download UFI image to install packages
/etc/process_packages.sh: line 148: can't create /.pkg/error.log: nonexistent directory
Package installation is incomplete, related functionalities may not be available
dhcpd executable file is not present.
Starting up system statistics daemon...
Starting systatsd done
Starting up health monitor daemon...
Log Level 7: Daemonized systatsd
Systatsd Logging Env is not set, initializing loglevel to: 7
Setting connection to systemlogger
Starting hmond done
Hmond Logging Env is not set, initializing loglelvel to: I
Backup is fine
Kernel crashdump is disabled.
dma_mem_base: 0x96000000, dma_mem_len: 0x8000000, warm_mem_base: 0x9f500000, warm_mem_len: 0xb00000
Creating TUN device
Starting TPM Infra
Group tss and User tss created
kernel.hostname = localhost
hostname set to localhost
Starting TCSD Daemon
TCSD Up and Running
Enabling time stamp.
Starting the FastIron.
USER=root
HOME=/
GCOV_PREFIX=/fast_iron
ethaddr=60:9c:9f:e6:2d:f9?
TERM=vt102
PATH=/sbin:/usr/sbin:/bin:/usr/bin
crashkernel=64M@0x70000000
ip=172.21.28.103:172.21.7.249::255.255.0.0:MN:eth0:off
SHELL=/bin/sh
PWD=/
i2c-0 i2c Broadcom iProc I2C adapter I2C adapter 2
i2c-1 i2c Broadcom iProc I2C adapter I2C adapter 2
FIPS Disabled:PORT NOT DISABLED
platform type 90
OS>
Loaded Image SPS08090e from Sec Built on (UTC): Tue Nov 19 12:27:26 2019
Enabling Console Logging
Installed CPLD Version 0x4:0x7
Recommended CPLD Version 0x4:0xa
Upgrading CPLD to 0x4:0xa
CPLD is upgraded Successfully !!!
!!WARNING: System is going to Power Cycle to load new CPLD !!
CPLD is upgraded Successfully !!!sil_ramfs_creat: Failed to create file /var/log/pdc/pdc_errorlog.txt
Could not create ramfs file!
pdc_errorlog
Could not open ramfs file!
fitrace_tmp.errorlogUpgrade from pre 8.0.80 image. Dual mode to VLAN config upgrade needed
Hotplugger Daemon Initialized ..
External USB disk is not mounted or plugged in.
Stopping health monitor daemon...
Stopped health monitor daemon
Sent SIGTERM to all processese = 116Stopping system statist
Sent SIGKILL to all processes
Requesting system reboot
[ 73.820342] reboot: Restarting system
[ 73.864242] Asserting GHPIO[7] reset sequence from Kernel ...
07-14-2020 09:01 AM
07-14-2020 10:43 AM
07-14-2020 11:27 AM
