ICX 7150-C12 Updates cause broken sectors.
kc_luchsinger
I'm trying to update an ICX7150-C12 with a newer firmware.  It's currently running 8.0.61a, and I am aware upgrading past this requires that you load both the firmware & the eUFI image, which I have done.  I can get the switch to update (on the Secondary Flash) and it seems to take the install as well as the reimage, but when you try to boot to secondary, it gives me a notice that it's "Skipping Bad Block", as seen below.  I've included my whole boot sequence here, as there's likely information in here about where my problem is occurring.  I'm upgrading via TFTP, and I have tried multiple different versions of firmware, with identical results.  I've also tried copying the primary flash back over to the secondary and starting from scratch to no avail.  Can anyone shed some light on this?
Booting image from Secondary
NAND read: device 0 offset 0x4000000, size 0x2000000
Skipping bad block 0x05a00000
Skipping bad block 0x05b00000
 33554432 bytes read: OK
## Loading kernel from FIT Image at 70000200 ...
   Using 'conf@1' configuration
   Trying 'kernel@2' kernel subimage
     Description:  Ruckus Linux MN VER=08.0.90e
     Type:         Kernel Image
     Compression:  lzma compressed
     Data Start:   0x7024fa00
     Data Size:    2401142 Bytes = 2.3 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x61008000
     Entry Point:  0x61008000
     Hash algo:    crc32
     Hash value:   8399a11a
     Type:         Kernel Image
     Architecture: ARM
     OS:           Linux
     Hash algo:    crc32
   Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 70000200 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  Ramdisk -rootfs
     Type:         RAMDisk Image
     Data Start:   0x704a072c
     Data Size:    23816895 Bytes = 22.7 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00000000
     Entry Point:  0x00000000
     Hash algo:    crc32
     Hash value:   e786d75c
## Loading fdt from FIT Image at 70000200 ...
   Trying 'fdt@3' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x7049e4d4
     Data Size:    8607 Bytes = 8.4 KiB
     Architecture: ARM
     Hash algo:    crc32
     Hash value:   6fc9a37b
   Loading fdt from 0x7049e4d4 to 0x65008000
   Booting using the fdt blob at 0x65008000
   Uncompressing Kernel Image ... OK
   Using Device Tree in place at 65008000, end 6500d19e
Starting kernel ...
Mounting file system...
booting with 4.4 kernel
PLATFORM MN
dd cmd: UBI
Config partition mounted
Resource partition is mounted!!
Please download UFI image to install packages
/etc/process_packages.sh: line 148: can't create /.pkg/error.log: nonexistent directory
Package installation is incomplete, related functionalities may not be available
dhcpd executable file is not present.
Starting up system statistics daemon...
Starting systatsd done
Starting up health monitor daemon...
Log Level 7: Daemonized systatsd
Systatsd Logging Env is not set, initializing loglevel to: 7
Setting connection to systemlogger
Starting hmond done
Hmond Logging Env is not set, initializing loglelvel to: I
Backup is fine
Kernel crashdump is disabled.
dma_mem_base: 0x96000000, dma_mem_len: 0x8000000, warm_mem_base: 0x9f500000, warm_mem_len: 0xb00000
Creating TUN device
Starting TPM Infra
Group tss and User tss created
kernel.hostname = localhost
hostname set to localhost
Starting TCSD Daemon
TCSD Up and Running
Enabling time stamp.
Starting the FastIron.
USER=root
HOME=/
GCOV_PREFIX=/fast_iron
ethaddr=60:9c:9f:e6:2d:f9?
TERM=vt102
PATH=/sbin:/usr/sbin:/bin:/usr/bin
crashkernel=64M@0x70000000
ip=172.21.28.103:172.21.7.249::255.255.0.0:MN:eth0:off
SHELL=/bin/sh
PWD=/
i2c-0   i2c             Broadcom iProc I2C adapter              I2C adapter    2
i2c-1   i2c             Broadcom iProc I2C adapter              I2C adapter    2
FIPS Disabled:PORT NOT DISABLED
platform type 90
OS>
Loaded Image SPS08090e from Sec Built on (UTC): Tue Nov 19 12:27:26 2019
Enabling Console Logging
Installed  CPLD Version  0x4:0x7
Recommended CPLD Version 0x4:0xa
Upgrading CPLD to 0x4:0xa
CPLD is upgraded Successfully !!!
!!WARNING: System is going to Power Cycle to load new CPLD !!
 CPLD is upgraded Successfully !!!sil_ramfs_creat: Failed to create file /var/log/pdc/pdc_errorlog.txt
Could not create ramfs file!
pdc_errorlog
Could not open ramfs file!
fitrace_tmp.errorlogUpgrade from pre 8.0.80 image. Dual mode to VLAN config upgrade needed
Hotplugger Daemon Initialized ..
External USB disk is not mounted or plugged in.
Stopping health monitor daemon...
Stopped health monitor daemon
Sent SIGTERM to all processese = 116Stopping system statist
Sent SIGKILL to all processes
Requesting system reboot
[   73.820342] reboot: Restarting system
[   73.864242] Asserting GHPIO[7] reset sequence from Kernel ...
3 REPLIES 3
steven_johnson_
I know that when I upgraded my firmware I had to upgrade to 8.0.80e (non-UFI) first. It appears that you tried to upgrade to 8.0.90eUFI (correct me if I am wrong).
Try downloading 8.0.80e and load the non-UFI image first. Then you should be able to upgrade to a UFI image after that.
Here are the files I upgraded using:
Boot image: 08080e\ICX7150\Boot\mnz10114.bin
Firmware image: 08080e\ICX7150\Images\SPR08080e.bin
Commands to load from a USB flash drive (your file paths could be different):
copy disk0 flash 08080e/ICX7150/Images/SPR08080e.bin primary
copy disk0 flash 08080e/ICX7150/Boot/mnz10114.bin bootrom
kc_luchsinger
Just tried to load 8.0.80e with identical results.
kc_luchsinger
I lied!  That seemed to do it, I just forgot to load the boot image!  Thanks!
Type a product name
