ICX 7150-24P corrupted flash?
Switch lost it's configuration after a power outage.
During boot i am getting the following messages:
Starting kernel ...
booting with 4.4 kernel
dd cmd: UBI
Config partition mounted
UBIFS error (ubi1:0 pid 566): ubifs_recover_leb: corrupt empty space LEB 11:249856, corruption starts at 767809
UBIFS error (ubi1:0 pid 566): ubifs_scanned_corruption: corruption at LEB 11:1017665
UBIFS error (ubi1:0 pid 566): ubifs_scanned_corruption: first 8192 bytes from LEB 11:1017665
UBIFS error (ubi1:0 pid 566): ubifs_recover_leb: LEB 11 scanning failed
mount: mounting ubi1:resources on /opt failed: Structure needs cleaning
Resource partition is mounted!!
Starting TPM Infra
Group tss and User tss created
kernel.hostname = localhost
hostname set to localhost
Starting TCSD Daemon
TCSD Up and Running
dma_mem_base: 0x96000000, dma_mem_len: 0x8000000, warm_mem_base: 0x9f500000, warm_mem_len: 0xb00000
Creating TUN device
Dumping the partition's content ...
Starting the FastIron.
Any help appreciated!
2 ACCEPTED SOLUTIONS
hashim_bharooc1
Contributor III
Hi Nomatch,
Hope you are doing Great.
Please open a tac case to work on this issue.
Please use following link to open a TAC case:
Hope this helps
Hashim
jijo_panangat
RUCKUS Team Member
Hello, You may try the below procedure for recovery, This will copy a fresh image from tftp server and boot from it incase of a corrupted image.
However, Software recovery should be performed under the supervision of a Ruckus support engineer
http://docs.ruckuswireless.com/fastiron/08.0.90/fastiron-08090-upgradeguide/GUID-9B5D5A56-039D-44FB-...
Jijo
4 REPLIES 4
hashim_bharooc1
Contributor III
Hi Nomatch,
Hope this helps
Hashim
Hello, this was a production switch and the issue needed to be delt with asap. We RMA'd it and already have a replacement up and running.
However for the future, is there a procedure for dealing with such issue, cli commands etc.
jijo_panangat
RUCKUS Team Member
Jijo
hashim_bharooc1
Contributor III
Hi Nomatch,
Jijo had already sent you a link with the procedure, did you check it out?
If not here it is again:
Hope this helps.
Hashim
