ICX 6450 DHCP not authoritative and not giving out IP addresses to some devices
kevindd992002
This is exactly what I am experiencing: https://forums.servethehome.com/index.php?threads/brocade-icx-series-cheap-powerful-10gbe-40gbe-swit...
Here's the relevant running-config of my 6450, nothing fancy:
So why would an enterprise switch be having this kind of no-brainer issue? When I plug in a windows device to the same port, I get an IP. When I plug the same nvr to another network (on a completey different house) with a pfsense DHCP server, it gets an IP just fine. So the problem is really the combination of the DHCP in this 6450 switch and the nvr.
5 REPLIES 5
Chandini
RUCKUS Team Member
Hi Kevin
Thanks for reaching us
From the details shared looks like there is data traffic going through the port. This issue may take time to understand the cause and may need details to be shared. Have you tried using debugs on the switch which is mentioned in the earlier post ?  Please feel free to log a case with us using the below link so that we can work with you to understand the problem.
