03-25-2019 06:24 AM
03-25-2019 12:01 PM
03-25-2019 12:02 PM
They completely missed that the point wasn't that I needed support but rather they need to get it over to the programmers who work on the 08.0.30 builds reporting it as a bug.
Any other ideas?
Hi Justin,
Thank you for contacting Ruckus Customer Support.
My name is Abhilash and I will be assisting you with Case # 00910840.
From your initial problem description, I understand that there is Reporting BUG. System Startup Time Not Correct in 08.0.30t.
Also you confirmed as rolled back to 08.0.30sa, which resolved the issue
As the issue, has been resolved the Case: 00910840 has been closed for now. Please feel free to contact me if you have any further concerns regarding the same.
We take this opportunity to thank you for your cooperation in resolving this issue. We hope the service provided to you was satisfactory and hope you will have a wonderful experience with Ruckus Networks in future too.
Please provide your valuable feedback for the service you received from me.
Thank you for contacting Ruckus Networks.
Yours sincerely,
Abhilash K. Nair | Customer Service Representative | Ruckus Networks Contact Us: https://support.ruckuswireless.com/contact-us
My working hours are Monday - Friday 0800-1700 EST Want to escalate this case? Please write an email to [email protected]
Ruckus Networks, an ARRIS company
ref:_00D506n2C._5002J1DQwrQ:ref03-25-2019 12:25 PM
Hi Justin,
My Name is Abhilash. This email is about the Case # 00910840.
Please Ignore my previous email.
I have assigned this case for Technical Assistance and one of our engineers will reach out to you to assist you further.
Case Number: 00910840
Issue Reported: Reporting BUG. System Startup Time Not Correct in 08.0.30t
Type: Technical Issue
Status: Assigned to Technical Team.
Priority: P303-26-2019 07:24 AM
Show ntp status shows time an hour off... the clock and logs show the correct time.
The boot time is a bit odd - I don't see a similar behavior for the boot time with a 7150 running 8.0.80 code... and NTP seems to show the same behavior.
SSH@switch-POE#show ver
Copyright (c) 1996-2016 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Feb 13 2019 at 17:44:50 labeled as ICX64S08030t
(8559704 bytes) from Primary ICX64S08030t.bin
SW: Version 08.0.30tT311
Boot-Monitor Image size = 786944, Version:10.1.05T310 (kxz10105)
HW: Stackable ICX6450-48-HPOE
UNIT 1: SL 1: ICX6450-48P POE 48-port Management Module
Serial #: xxx
License: BASE_SOFT_PACKAGE (LID: dbvIHINmFdg)
P-ENGINE 0: type DEF0, rev 01
P-ENGINE 1: type DEF0, rev 01
UNIT 1: SL 2: ICX6450-SFP-Plus 4port 40G Module
800 MHz ARM processor ARMv5TE, 400 MHz bus
65536 KB flash memory
512 MB DRAM
STACKID 1 system uptime is 13 day(s) 1 hour(s) 35 minute(s) 15 second(s)
The system started at 16:00:38 Pacific Wed Dec 31 1969
The system : started=warm start reloaded=by "reload"
SSH@switch-POE#sh clock
07:08:37.087 Pacific Tue Mar 26 2019
SSH@switch-POE#show ntp stat
Clock is synchronized, stratum 6, reference clock is 10.0.0.30
precision is 2**-16
reference time is 3762598055.4164417462 (06:07:35.4164417462 Pacific Tue Mar 26 2019)
clock offset is -10.2223 msec, root delay is 127.8859 msec
root dispersion is 160.9910 msec, peer dispersion is 130.4432 msec
system poll interval is 64, last clock update was 99 sec ago
NTP server mode is enabled, NTP client mode is enabled
NTP master mode is disabled, NTP master stratum is 8
NTP is not in panic mode
SSH@switch-POE#sh ver
Copyright (c) 2017 Ruckus Wireless, Inc. All rights reserved.
UNIT 1: compiled on Nov 20 2018 at 00:09:55 labeled as SPS08080d
(25968884 bytes) from Primary SPS08080d.bin
SW: Version 08.0.80dT211
Compressed Boot-Monitor Image size = 786944, Version:10.1.14T225 (mnz10114)
Compiled on Thu Nov 15 04:59:22 2018
HW: Stackable ICX7150-24-POE
UNIT 1: SL 1: ICX7150-24P-4X10GR POE 24-port Management Module
Serial #:xxx
Current License: 4X10GR
UNIT 1: SL 3: ICX7150-4X10GF 4-port 40G Module
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 70 day(s) 2 hour(s) 36 minute(s) 28 second(s)
The system started at 04:01:04 Pacific Tue Jan 15 2019
SSH@switch-POE#show clock
07:19:45.110 Pacific Tue Mar 26 2019
precision is 2**-16
reference time is 3762598590.3873852468 (06:16:30.3873852468 Pacific Tue Mar 26 2019)
clock offset is -21.7787 msec, root delay is 127.8890 msec
root dispersion is 179.5589 msec, peer dispersion is 138.1137 msec
system poll interval is 64, last clock update was 198 sec ago
03-26-2019 10:09 AM
