I broke a 7450 stack
clayton_taverni
Contributor
We had a stack set up with a 7650 and 5 7450s.  There's an issue with the primary and secondary flash on one of the 7450s and, in trying to fix it, I rebooted the stack.  Now, the last two switches have been dropped from the stack and I would like some help getting them back.
SSH@STACK#show spx
T=4h39m10.5: alone: standalone, 😧 dynamic cfg, S: static
ID   Type          Role    Mac Address    Pri State   Comment
1  S ICX7650-48ZP  alone   d4c1.9e14.78c3   0 local   Ready
21 S ICX7450-48P   spx-pe  d4c1.9e08.2440 N/A remote  Ready
22 S ICX7450-48P   spx-pe  d4c1.9e07.f680 N/A remote  Ready
23 S ICX7450-48P   spx-pe  d4c1.9e08.1f00 N/A remote  Ready
24 S ICX7450-48P   spx-pe  0000.0000.0000 N/A reserve
25 S ICX7450-48P   spx-pe  0000.0000.0000 N/A reserve
  3/1| 1 |3/3
  1/3/2--3/1| 21 |4/1--3/1| 22 |4/1--3/1| 23 |4/1-
This is from before the reboot:
SSH@STACK#show flash
Stack unit 1:
  Compressed Pri Code size = 56904124, Version:08.0.80bT233 (TNR08080b.bin)
  Compressed Sec Code size = 56904124, Version:08.0.80bT233 (TNR08080b.bin)
  Compressed Boot-Monitor Image size = 1573376, Version:10.1.13T235
  Code Flash Free Space = 2802184192
SPX unit 21:
  Compressed Pri Code size = 29815996, Version:08.0.80bT213 (SPR08080b.bin)
  Compressed Sec Code size = 29815996, Version:08.0.80bT213 (SPR08080b.bin)
  Compressed Boot-Monitor Image size = 786432, Version:10.1.13T215
  Code Flash Free Space = 1697820672
SPX unit 22:
SPX unit 23:
  Code Flash Free Space = 1697816576
SPX unit 24:
  Compressed Pri Code size = -1523736068, Version:08.0.80T213 (SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0�-��08.0.80T213)
  Compressed Sec Code size = -1523736068, Version:08.0.80T213 (SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0SPR0�-��10.1.12T215)
  Compressed Boot-Monitor Image size = 786944, Version:10.1.12T215
  Code Flash Free Space = 1760612352
SPX unit 25:
Suggestions?
19 REPLIES 19
hashim_bharooc1
RUCKUS Team Member
Hey Clayton,
-You need to check if the images on the missing units are intact by  consoling to it.  Make sure it is same image version.  Also try to recopy the files that was corrupted on the unit 24.
-Also you can check if the SPX  Stack ports are up. (show spx connections)
-Check log files for any information as to why it fell off the stack.
I think it would be a good idea to open up a ticket as it might be a bit more complex.
clayton_taverni
Contributor
Thanks.  When I console to the #24 switch, I get a "ICX7450-Boot>" prompt and I couldn't see which commands to use to access the flash memory.
Also, I thought one of the selling points of a stack configuration was that you could add a new switch, cable it up and issue one command to add it to the stack.  Don't I just need that command to re-add these two switches to the stack?
SSH@STACK#show spx connections
Probing the topology. Please wait ...
Discovered following spx connections...
Link 1: # of ports in lag = 1
       1: 1/3/2 <--> 21/3/1
Link 2: # of ports in lag = 1
       1: 21/4/1 <--> 22/3/1
Link 3: # of ports in lag = 1
       1: 22/4/1 <--> 23/3/1
Discovery complete
hashim_bharooc1
RUCKUS Team Member
Hey Clayton,
We need to debug this further, it is stuck in boot monitor.
Best thing is to open a case and work with TAC.
clayton_taverni
Contributor
Thanks for your help.
Type a product name
