How to set up ICX7150-C12-Switch for the first time?
kleindmjre
I'm newbie.  I have a ICX7150-C12-Switch and I have things that need POI ports.  All the ports were working for 5 days and now they are not.  What do I do?  I need a flow chart or something that shows me the correct settings.
1 REPLY 1
BenBeck
Hey @kleindmjre
Do you have access to the CLI? Can you please issue:
show inline power detail
Depending on the code level ('show version' to check), you may need to enable POE on the interfaces with a command such as:
conf t
interface eth 1/1/1 to 1/1/12
inline power
