02-21-2024 02:47 AM
We have a 7150-48ZP switch on firmware SPR09010f which is primarily used for access points. Over the past week it has been alerting 30% and 50% CPU usage every few minutes. It has been fine prior to this. Could someone advise on what the cause could be or where I can go to check for any errors? The show log command doesn't appear to show much.
Any help appreciated!
02-21-2024 04:03 AM - edited 02-21-2024 04:17 AM
Hi ctg24 ,
Thank you for posting your query !!!
I understand that you have a 7150-48ZP with Code SPR09010f and you are facing a high cpu usage issue in every few min, And you would like to check for any errors and the cause of the issue.
There can be many cause for high cpu for example given below:
High CPU Cause #1: Depletion of Hardware Resources
High CPU Cause #2: Layer Two Loop in the Network
High CPU Cause #3: Common Services: SFLOW and SNMP
High CPU Cause #4: Features that Trigger CPU Forwarding
There are a small number of features that trigger CPU forwarding / software forwarding by design. This can vary by platform. Please refer to device-specific documentation for clarification. Features that may trigger CPU forwarding include:
1. Policy-based routing
2. Egress ACLs
3. Ip-subnet VLAN
4. Protocol VLANs
5. Private VLANs
6. Uplink Switch
For high cpu troubleshooting we use the below commands:
show cpu (3 times every one minute)
show cpu task (3 times every one minute)
de (3 times)
sh stat (3 times)
show int | inc line|util (3 times every one minute)
show memory (3 times)
show arp resource
show ip route
show ip pim resource
Show ip multicast resource
show ip traffic
You can use dm raw to see what kind of packets are hitting the cpu. Here are the steps:
Note: Please use DM raw under tac supervision as it might affect production
The Below command usage vary in different scenarios for example :
* If you're connected via SSH:
If you are connected via ssh or telnet, you also need to specify the session # which can be checked with the show who command.
- Sh who
To see which SSH session you're in
- Debug destination ssh X
To direct the logs to the SSH we're in
- Debug dest ssh x
- Dm raw mode brief
- Dm raw filter none
- Dm raw max 20
- Dm raw
But in case you are connected via console then use the below process :
* If you're connected via Console session:
- Dm raw mode brief
- Dm raw max 20
- Dm raw
Moving Forward the dm raw utility is a debug which will show the packets that are hitting the cpu. This will tell us if there is any specific traffic that is causing the high cpu spikes. But we always suggest our customer to use this command under tac supervision.
You can also refer the below short video for more information on DM raw command :
https://youtu.be/6a18tpkE_y4?si=IZB0H3tTCQtXnL0p
Moving Forward If this issue is not resolved , Please log a ticket with the below link so that we will help you further.
I hope this information helps you
Please feel free to leave us a message if any concerns
07-26-2024 05:19 AM
@Mayank wrote:Hi ctg24 ,
2. Egress ACLs
3. Ip-subnet VLAN
4. Protocol VLANs
5. Private VLANs
6. Uplink Switch
de (3 times)
sh stat (3 times)
show memory (3 times)show arp resource
show ip route
show ip trafficYou can use dm raw to see what kind of packets are hitting the cpu. Here are the steps:
- Sh who
- Debug dest ssh x
- Dm raw mode brief
- Dm raw max 20
- Dm rawBut in case you are connected via console then use the below process :
- Dm raw mode brief
- Dm raw max 20
- Dm rawMoving Forward the dm raw utility is a debug which will show the packets that are hitting the cpu. This will tell us if there is any specific traffic that is causing the high cpu spikes. But we always suggest our customer to use this command under tac supervision.
02-22-2024 06:21 AM
Thank you both, will give this a shot tonight out of hours and let you know how it goes!
02-27-2024 03:42 AM - edited 02-27-2024 03:42 AM
Got tied up so didn't get a chance last night, however have now managed to run them please see links below to output for both commands and vSZ health of the switch:
https://www.pastly.de/gqrpkpwwif
Thanks again!
