07-09-2020 12:40 PM
vlan 16 name OfficeHowever, when I try to create the trunk ports, I hit an issue:
tagged ethernet 1/1/12
ICX7150-C12 Router(config-if-e1000-1/1/1)#vlan-config add all-taggedI checked, and port 1/1/1 does have an IP address - it seems to have pulled one via DHCP by default. (And I can also use this IP address to SSH into the switch and configure things).
INFO : Command may take approximately 0 Seconds
error - IP routing, vrf, ip policy, route-only, rpf-mode, ip-mac or ip tcp mss was configured on ports 1/1/1
ICX7150-C12 Router(config-if-e1000-1/1/1)#int eth 1/1/1However, the IP address seems to come back on its own after a couple of minutes.
ICX7150-C12 Router(config-if-e1000-1/1/1)#no ip address *
VLAN : [ 82]
Port(s) ethe 1/1/1 add to 2 vlan(s) complete.....
07-09-2020 01:40 PM
I haven't seen an example of multiple VLAN tagged which I think is
what he wanted so here goes
First state the vlans (five in
this example, 2, 4, 7, 10, 40)
config)# VLAN 2 4 7 10 40
Then tag those to the interface
config-vlan 2*40# tag int e 1/1/1
Done!
save your work, tho 🙂
07-09-2020 02:07 PM
06-16-2022 03:09 AM
Dear Sir,
We have tried all possibilities, but no luck.
Can u please provide me a commands for trunk configuration, request.
for RUCKUS ICX 7510- 24port switch
Thanks and Regards
Fenny Kumar
10-29-2022 02:38 AM
Fenny I am no expert but trunk ports work without issue. I have setup trunks between ICX, Telesis Switches and a Trunk to ESX distributed switch in a home lab environment. You may be having some difficulty if you are used to setting up Cisco trunks, the terminology is quite different with other switch OS's. A trunk in Ruckus is associated to aggregation groups unlike Cisco a trunk is actually a port with multiple VLAN's that are pre tagged to traverse that interface.
enab
conf t
vlan 10 #creates vlan 10 (if not already created)
vlan 2048 #
--------->So now tag the interface to the VLAN (reverse of how Cisco does trunks)
SSH@CoreSwitch(config)#vlan 10
SSH@CoreSwitch(config-vlan-10)#tagged ethernet 1/1/8
Added tagged port(s) ethe 1/1/8 to port-vlan 10.
SSH@CoreSwitch(config-vlan-10)#exit
SSH@CoreSwitch(config)#vlan 2048
SSH@CoreSwitch(config-vlan-2048)#tagged ethernet 1/1/8
Added tagged port(s) ethe 1/1/8 to port-vlan 2048.
--------->Now ether 1/1/8 is effectively (in Cisco language) a trunk for vlan 10 & 2048
--------->That's it
