08-07-2022 10:42 AM
Come from Aruba, Cisco background
I found ICX OS need to be improved
1. can't ping in Config mode
must exit to Global mode to ping
that make extra headache for me
ARUBA # ping (no matter where we are)
CISCO # do ping
FORTI # exe ping
2. ctrl-z
when I in interface mode
ARUBA 1x press ctrl-z will move you to config mode, 1x press ctrl-z again, it will move to Global mode
RUCKUS 1x press ctrl-z will move you directly to Global mode
3. must conf t instead of just conf
ARUBA conf is enough although "conf t" is available for backward compatibility
4. interface must e 1/1/1
ARUBA # int 1
RUCKUS maybe can follow ARUBA way. just issue "int 1" for local interface
5. fastboot
ARUBA
https://techhub.hpe.com/eginfolib/networking/docs/switches/common/15-18/5998-8158_bog/content/ch04s0...
RUCKUS is there a similar way
6. device-profile
ARUBA CISCO has device-profile
RUCKUS where I can find device-profile
08-07-2022 10:48 AM
Hey @nbctcp
Feedback is always encouraged, but the forum is not the right avenue to submit feature requests. These will have to go through your account team and then they can submit the ideas on your behalf.
08-07-2022 10:48 AM
Hey @nbctcp
