It looks like the linecard is IPv6 while your chassis is IPv4. I'm not sure if it is even possible anymore as the switch it end of support, but you used to be able to upgrade the chassis via "FESX648-L3U-IPV6" license. I think that would be the only way to use the IPv6 module.
Ben Beck, RCNA, Principal Technical Support Engineer
