FCX reload with dhcpv6 snooping
ricardo_mussini
I've set up ipv6 dhcp snooping and this is causing the unexpected reload of the switch stack. The stack consists of 4 FCX-648GS, two with POE +. The FI version is 08.0.30t. The VLAN has a VE interface configured on an MLX-8. The strange thing is that another place has the same configuration and the same does not happen. Any idea what that might be?
6 REPLIES 6
BenBeck
in 'show version', is it being reported as a warm or cold start? Also, please see if there is any data in 'dm save <1-4>. If you are seeing a crash, I would recommend opening a case with a show tech and output mentioned prior.
was warm start and there is a lot of data on dm save 1.
Got it. Please submit a case with the following and we can analyze:
show tech
dm save 1
dm save 2
dm save 3
dm save 4
Done. Case ID: 00955174
