โ04-03-2025 04:12 PM
I'm currently working with Ruckus ICX switches and have encountered a couple of challenges regarding Dynamic Port Profiles:โ
Is there a method to prevent certain ports from being assigned dynamic port profiles? We've observed that some OUI-based profiles are being applied to ports connected to other switches. It seems that the MAC addresses of devices connected to these downstream switches match the OUI criteria, leading to unintended profile assignments.โ
Any insights or guidance on these issues would be greatly appreciated.
โ04-29-2025 08:42 AM
Hi Matthewlampe
Thank you for reaching us
Based on the details shared, I understand that you are looking for options to remove a port from a port profile. This port is part of a switch-to-switch link, and the port profile is being applied to this link, which should not be the case.
Could you help us with below details
Thank you
โ04-29-2025 09:10 AM
This was last year on an earlier version on 8200. Have they patched it to where it doesn't apply to switch-to-switch links? Is there any documentation on that?
โ04-30-2025 04:35 AM
Hi Matthewlampe
Are you still experiencing the issue, or was it observed in an older version of the 8200 switch? If the issue was resolved after upgrading, could you please let me know which version fixed it?
Thank you
