โ07-04-2024 01:54 AM
When the ruckus switch (ICX 7850) is connected to the cisco switch, can the ERSPAN & RSPAN function work normally?
โ07-05-2024 10:15 AM - edited โ07-05-2024 10:16 AM
Hi jjchiou,
Thank you for reaching us out on the query.
With regards to the RSPAN settings, with Cross vendor environment we would need to check if the same can work or otherwise.
Could you help us with below so that we could check into it further,
Thanks !!
-Joshua
โ07-07-2024 07:35 PM
Would the mirrored traffic from the 7850s traverse through connected Cisco Peer ? ( I donโt know if mirrored traffic from the 7850s traverse through connected Cisco Peer or mirrored traffic from the cisco traverse through connected 7850 Peer)
User just want check Ruckus ICX 7850-48F peering with the cisco switch , the ERSPAN function is work well ใ
by the way , I ca't reply your mail directly ใ
โ07-07-2024 07:37 PM
and I can't upload a image as you askedใ
โ07-08-2024 04:52 AM
Hi jjchiou,
Here as the question is specific on interoperability, would need to know exactly how/what its intended use case would be, as with that we could check further specifically with respect to the bit thats in question.
You should be able to attach the Topology snap/picture on to the comment, with that it would be easier for to follow the flow of traffic and understand the query better.
-Joshua
