your reply answer my problem here
https://forums.ruckuswireless.com/ruckuswireless/topics/icx-questions?utm_source=notification&ut...STEPS
-to create alias
#conf t
#alias bkup=copy flash flash file startup-config backup
#alias restor=copy flash flash file backup startup-config
-to create a cron job
#conf t
#batch buffer 1 &
#restor &
#end
#execute batch 1 after 00:00:01
#sh batch schedule
Batch buffer 1 will be executed 0 days 0 hours 0 minutes 52 seconds from now
NOTE:
-can't put reload on batch
http://docs.ruckuswireless.com/fastiron/08.0.61/fastiron-08061-commandref/GUID-02AE6631-717F-4E29-92...-to reload after 2min
#reload 00:00:02
Those steps achieve my goal but almost perfect because
1. I can't put reload in batch (see notes above), that's why I need to put batch and reload in consecutive order
2. will be better if I can copy backup to running-config directly
I can do that but not affect current running-confg
for example
current hostname SW1
wr me
copy startup-config to backup
change hostname to SW2
those wont change my running hostname
