Create VLAN via SNMP on ICX6430
Running into difficulties creating a VLAN on the ICX6430 using SNMP, but I do have it working on the ICX7150
7150, confirmed working, creates VLAN 114:
snmpset -v 3 -u GROUPNAME -l authPriv -a SHA -A PASSWORD -x AES -X PASSWORD -t 3 IPADDRESS 1.3.6.1.4.1.1991.1.1.3.2.1.1.10 i 4 1.3.6.1.4.1.1991.1.1.3.2.1.1.2 i 114
iso.3.6.1.4.1.1991.1.1.3.2.1.1.10 = INTEGER: 4
iso.3.6.1.4.1.1991.1.1.3.2.1.1.2 = INTEGER: 114
6430, not working:
Error in packet.
Reason: undoFailed
Failed object: iso.3.6.1.4.1.1991.1.1.3.2.1.1.10
However, I can delete a VLAN on the 6430, deletes VLAN 114:
snmpset -v 3 -u GROUPNAME -l authPriv -a SHA -A PASSWORD -x AES -X PASSWORD -t 3 IPADDRESS 1.3.6.1.4.1.1991.1.1.3.2.1.1.10 i 3 1.3.6.1.4.1.1991.1.1.3.2.1.1.2 i 114
SNMPv2-SMI::enterprises.1991.1.1.3.2.1.1.10 = INTEGER: 3
SNMPv2-SMI::enterprises.1991.1.1.3.2.1.1.2 = INTEGER: 114
Any ideas on why I wouldn't be able to add a VLAN on the 6430?
Thanks,
Jennifer
10 REPLIES 10
We don't use SNMPv2, but I can try it out today.  Thanks Jijo.
I will open a case as well
