Cisco AP not getting enough power off a 6430-48P
I am trying to get my Cisco 3602I with AC Module to work with 30W. I have configured it on the switch saying CDP enable and max power available on the port set to 30000.
BROCADE:Image_ images_messages_5f91c3f8135b77e247902f08_c5851d44690ca2cf42d8b546fb29a1c4_RackMultipart20190628108895yn7-ba971e52-3cf2-43a2-895f-93eed2bb8d87-368446127.png1561765397
CISCO: Image_ images_messages_5f91c3f8135b77e247902f08_a6ccc4ea62b02e2f8b1c235b9faca1e2_RackMultipart2019062847110dt94-c4217810-f3ce-4b52-bfc5-2c9d64ecd4e7-775103243.png1561765394
14 REPLIES 14
I realize this switch doesn't have any 30W devices, but I see those run all the time without issues on various ICX switches, and I am not going out of my way to set the ports to any strange settings!
If you are not running the latest, please upgrade the device!
Here is an example interface:
interface ethernet 1/1/10
 dual-mode  144
 inline power
 trust dscp
These are enabled, too:
cdp run
lldp run
fdp run
If you want to upgrade:
First verify what you are booting to (primary or secondary... Default = Primary or if Primary fails then boot Secondary).  If it is default, leave it alone:
SSH@Redacted#sh boot
Boot system preference(Configured):
        Use Default
Boot system preference(Default):
        Boot system flash primary
        Boot system flash secondary
SSH@Museum5-2West#
SSH@Redacted#sh fl
Stack unit 1:
  Compressed Pri Code size = 8559140, Version:08.0.30sT311 (ICX64S08030sa.bin)
  Compressed Sec Code size = 8533104, Version:08.0.30mT311 (ICX64S08030mb.bin)
  Compressed Boot-Monitor Image size = 786944, Version:10.1.05T310
  Code Flash Free Space = 5677056
Here is the inline power detail. I have enabled LLDP, CDP and FDP enabled on 1/1/4.
Power Supply Data On stack 1:
Power Supply Data:
Power Supply #1:
        Max Curr:       6.8 Amps
        Voltage:        54.0 Volts
        Capacity:       370 Watts
power supply 2 is not present
POE Details Info. On Stack 1 :
General PoE Data:
Firmware
Version
02.1.0
Cumulative Port State Data:
#Ports    #Ports     #Ports   #Ports    #Ports       #Ports     #Ports
Admin-On  Admin-Off  Oper-On  Oper-Off  Off-Denied   Off-No-PD  Off-Fault
10        38         3        45        0            7          5
Cumulative Port Power Data:
#Ports  #Ports  #Ports        Power       Power
Pri: 1  Pri: 2  Pri: 3  Consumption  Allocation
1       0       9          25.822 W    60.800 W
Flash firmware is here.
  Compressed Pri Code size = 10371776, Version:07.4.00bT311 (ICX64S08030t.bin)
  Compressed Sec Code size = 10371776, Version:07.4.00bT311 (ICX64S08030t.bin)
  Code Flash Free Space = 5894144
The boot information is set to boot primary then secondary.
Let me know if you need to look at anything else.
Good Morning:
I would upgrade the POE firmware next.  Using the same TFTP server you used to send 08030t navigate to the folder with the firmware file and send it like this substituting your computer's IP for 10.1.2.3:
Command:
inline power install-firmware stack-unit 1 tftp 10.1.2.3 icx64xx_poeplus_02.1.0.b004.fw
This will take all POE offline for about 12 minutes, so I would NOT do it in the middle of the work day if you have a bunch of users on VoIP phones!  This cannot be automatically scheduled on the switch itself though you could probably have some management software send the command at a time of your choosing.
Make certain the power is stable etc.; since, any loss of power will likely brick the POE controller necessitating a TAC case and most likely an RMA (if they still do that for the 64xx units).  I have only had one out of maybe 300 of these fail after this upgrade, but it was already flaky with a bad power supply.  You can check that with "show chassis"
If you are doing this over SSH, you will want to enable "term mon" or "terminal monitor" to watch the syslog messages scroll by the screen, so you know when it is done.
Otherwise you will be typing "show logging" to check the syslog for status.
If your unit is stacked, you need to do this for each unit... otherwise the one and only unit is #1 and the command above will simply work.  If in doubt, you can use "show stack."  Though I doubt this is the use case given your outputs list only one unit.
Afterwords, running the "show inline power detail" command should return:
Firmware
Version
02.1.0 Build 004
Hello. I have updated my firmware and still have the issue. I have posted my PoE detail below.
Power Supply Data:
Power Supply #1:
        Max Curr:       6.8 Amps
        Voltage:        54.0 Volts
        Capacity:       370 Watts
General PoE Data:
Firmware
Version
02.1.0
10        38         3        45        0            7          5
1       0       9          22.629 W    40.500 W
Your output doesn't seem to indicate the POE update successfully installed.
If it were successful, it would display this:
Firmware
Version
02.1.0 Build 004
NOT
Firmware
Version
02.1.0
