03-08-2021 06:03 AM
Having issues configuring a new Dynamic Lag between Brocade ICX 6610 to Dell s4112t-on, both switches on the latest firmware. Configuration looks good on both sides but no success. I have tested the Dell switch to a cisco switch I had recently taken out of service and that lag works. I have also tested the Brocade stack to that same cisco switch and it works. When I connect the Dell Switch to the Brocade switch, the ports show as up however in a BLOCKED state. Port is up, line protocol is down (LACP-BLOCKED) Port down (LACP-BLOCKED).
Any suggestions/ideas/tips would be GREATLY appreciated.
03-09-2021 04:06 AM
Hi Jeff,
Pls check if the ports have the same speed & duplex on both ends, Also try to match the lacp timeout configured on both sides.
Hope they are not blocked by STP.
Jijo
03-09-2021 04:07 AM
Hi Jeff,
Pls check if the ports have the same speed & duplex on both ends, Also try to match the lacp timeout configured.
Jijo
