07-20-2025 03:50 AM
Hi
After upgrading my 7150 to the latest version it doesn't recognize my user/password
I connected through USB cable, interrupted the boot by pressing "b", choosed "no password" then "boot" but it's still asking for a login/password
I tried super/sp-admin with no success
What shall I do ?
07-21-2025 03:27 AM - edited 07-21-2025 03:28 AM
Hi plc ,
Thank you for posting your query !!!
I understand that you are facing password issue.
If you are running 9.0.10 code or newer versions, please use this method :
Press Ctrl and Y to enter OS configuration mode.
Enter reset_login to reset login details.
OS> reset_login
This is a temporary login. Please reconfigure users once you login.
OS>exit
Note: You must enter super for Login and sp-admin for password.
Enter the exit command to return to user EXEC mode. Press enter. You are prompted for your username (super) and password (sp-admin)
I hope this information helps you
Please feel free to leave us a message if any concerns
Note: Please feel free to mark the post as ACCEPTED SOLUTIONS if its addressed your query.
Mayank
07-23-2025 01:06 AM
Hi plc,
Glad to know that the issue has been resolved,
For 7150 the recommend code is 8095s.
Please refer to the below link for your reference :
Regarding your query on no SPS in 10.0.10g version below is the explanation:
The Switching image was deprecated with 10.0 and each platform will only use one image starting with 10.0.
ALL the L3 image support L2 features starting with 10.0, Only routing image are available for all supported models. Switching features are still available in the routing image.
Mayank
07-20-2025 06:18 AM
The swith is an ICX7150‑48P,
It is supposed to be supported both in SPS08095s and SPS09010k
But when I upgrde to SPS09010k my login.password don't work. Booting back to the previous version is OK
Hi plc ,
OS> reset_login
OS>exit
Mayank
07-21-2025 04:45 AM
Yes, it works. You rock !
The explanation is that I had 2 users, root and a "no password" user. Both were removed by version 9 so I was unable to login !
I recreated another user with your advices and it worked. Thanks !
On last question : in version 10 Releses I only find the SPR (router) release and no SPS while the 7150-48P is supposed to be supported in 10.0.10g revision. Does the Router version works on my 7150 ?
Thnaks again
07-23-2025 01:06 AM
Hi plc,
Mayank
