6450 stack w/8030n issues?
I'm working on setting up a 4 unit stack of ICX 6450-48s.  Firmware installed is 8.0.3n - Routing.  I am getting a continuous stream of the following entries to the console port:
T=17h5m20.1: Election, was active, no change, ID=1, pri=128, 4U(1-4), A=u1, nbr#=3 3, reason: u2: port-up, ,
T=17h5m57.7: Election, was active, no change, ID=1, pri=128, 4U(1-4), A=u1, nbr#=3 3, reason: u2: port-up, ,
T=17h7m59.8: Election, was active, no change, ID=1, pri=128, 4U(1-4), A=u1, nbr#=3 3, reason: u2: port-dw, ,
T=17h8m9.4: 1/2/1 goes down. delete direction 0, trigger election
T=17h11m20.3: Election, was active, no change, ID=1, pri=128, 4U(1-4), A=u1, nbr#=3 3, reason: u2: port-up, ,
T=17h13m56.9: Election, was active, no change, ID=1, pri=128, 4U(1-4), A=u1, nbr#=3 3, reason: u2: port-dw, ,
T=17h17m9.5: 1/2/1 goes down. delete direction 0, trigger election
T=17h17m38.5: Election, was active, no change, ID=1, pri=128, 4U(1-4), A=u1, nbr#=3 3, reason: u2: port-dw, ,
In addition the input errors and CRC numbers are steadily increasing.
I'm using the standard 1m stacking cables.
Does anyone know what might be happening?  Is there a different version of firmware (earlier/later) that I should be using instead?
Any help is appreciated.
Todd
10 REPLIES 10
BenBeck
If a stack port flaps or loses communication, it will trigger an election. You need to clean up the stack ports if you are seeing errors. What is the media type? Have you tried other cables? Can you gather the following:
show stack
show stat e 1/2/1 e 1/2/3 e 2/2/1 e 2/2/3 (assuming these are the stack ports)
dm statistic
show media
show log
dm statistic shows the following info for the relevant stack ports:
123-0-0-0(1/2/1)
31-0-0-0(1/2/3)
3-0-0-0(2/2/1)
3-0-0-0(2/2/3)
5-0-0-0(3/2/1)
5-0-0-0(3/2/3)
3-0-0-0(4/2/1)
3-0-0-0(4/2/3)
Show Media:
show media | ex M-C
Port 1/2/1:  Type : 1GE Twinax   1m (SFP)
Port 1/2/3:  Type : 1GE Twinax   1m (SFP)
Port 2/2/1:  Type : 1GE Twinax   1m (SFP)
Port 2/2/3:  Type : 1GE Twinax   1m (SFP)
Port 3/2/1:  Type : 1GE Twinax   1m (SFP)
Port 3/2/3:  Type : 1GE Twinax   1m (SFP)
Port 4/2/1:  Type : 1GE Twinax   1m (SFP)
Port 4/2/3:  Type : 1GE Twinax   1m (SFP)
Show stack:
ID   Type          Role    Mac Address    Pri State   Comment
1  S ICX6450-48    active  609c.9f92.5dc0 128 local   Ready
2  S ICX6450-48    member  609c.9f92.6680   0 remote  Ready
3  S ICX6450-48    member  609c.9f92.66c0   0 remote  Ready, standby if reloaded
4  S ICX6450-48    member  609c.9f92.6200   0 remote  Ready
    active
 -2/1| 1 |2/3--2/1| 4 |2/3--2/1| 3 |2/3--2/1| 2 |2/3-
Note: There is no standby. Reason: u2: unknown, u3: unknown, u4: unknown,
Current stack management MAC is 609c.9f92.5dc0
show stat
Port       Link    State   Dupl Speed Trunk Tag Pvid Pri MAC             Name
1/2/1      Up      Forward Full 10G   None  No  N/A  0   609c.9f92.5df1
 Port 1/2/1 Counters:
         InOctets            669139368           OutOctets             23361464
           InPkts               491349             OutPkts               158425
  InBroadcastPkts                    0    OutBroadcastPkts                    0
  InMulticastPkts               491349    OutMulticastPkts               158425
    InUnicastPkts                    0      OutUnicastPkts                    0
        InBadPkts               224304
      InFragments                    0
       InDiscards                    0           OutErrors                    0
              CRC               224304          Collisions                    0
         InErrors                30455      LateCollisions                    0
      InGiantPkts                    0
      InShortPkts                    0
         InJabber                    0
   InFlowCtrlPkts                    0     OutFlowCtrlPkts                    0
     InBitsPerSec              1587096       OutBitsPerSec                42312
     InPktsPerSec                  145       OutPktsPerSec                   44
    InUtilization                0.01%      OutUtilization                0.00%
1/2/3      Up      Forward Full 10G   None  No  N/A  0   609c.9f92.5df3
 Port 1/2/3 Counters:
         InOctets            137094532           OutOctets             12410120
           InPkts               253079             OutPkts                39417
  InMulticastPkts               253079    OutMulticastPkts                39417
        InBadPkts                12203
      InFragments                    0
              CRC                12203          Collisions                    0
         InErrors                 1426      LateCollisions                    0
      InGiantPkts                    0
      InShortPkts                    0
         InJabber                    0
     InBitsPerSec               331328       OutBitsPerSec                26888
     InPktsPerSec                   76       OutPktsPerSec                   11
    InUtilization                0.00%      OutUtilization                0.00%
2/2/1      Up      Forward Full 10G   None  No  N/A  0   609c.9f92.66b1
 Port 2/2/1 Counters:
         InOctets             62319460           OutOctets              4065972
           InPkts               118924             OutPkts                12774
  InMulticastPkts               118924    OutMulticastPkts                12774
        InBadPkts                 2102
      InFragments                    0
              CRC                 2102          Collisions                    0
         InErrors                  255      LateCollisions                    0
      InGiantPkts                    0
      InShortPkts                    0
         InJabber                    0
     InBitsPerSec               144760       OutBitsPerSec                 9856
     InPktsPerSec                   35       OutPktsPerSec                    3
2/2/3      Up      Forward Full 10G   None  No  N/A  0   609c.9f92.66b3
 Port 2/2/3 Counters:
         InOctets              8487136           OutOctets            327235660
           InPkts                39114             OutPkts               362168
  InMulticastPkts                39114    OutMulticastPkts               362168
        InBadPkts                 6928
      InFragments                    3
              CRC                 6928          Collisions                    0
         InErrors                 1982      LateCollisions                    0
      InGiantPkts                    0
      InShortPkts                    0
         InJabber                    0
     InBitsPerSec                17024       OutBitsPerSec               912552
     InPktsPerSec                   12       OutPktsPerSec                  125
3/2/1      Up      Forward Full 10G   None  No  N/A  0   609c.9f92.66f1
 Port 3/2/1 Counters:
         InOctets              4682052           OutOctets              3859780
           InPkts                12553             OutPkts                11721
  InMulticastPkts                12553    OutMulticastPkts                11721
        InBadPkts                  564
      InFragments                    0
              CRC                  564          Collisions                    0
         InErrors                   85      LateCollisions                    0
      InGiantPkts                    0
      InShortPkts                    0
         InJabber                    0
     InBitsPerSec                 8448       OutBitsPerSec                 8560
     InPktsPerSec                    3       OutPktsPerSec                    3
3/2/3      Up      Forward Full 10G   None  No  N/A  0   609c.9f92.66f3
 Port 3/2/3 Counters:
         InOctets              4225704           OutOctets             66324944
           InPkts                12550             OutPkts               127644
  InMulticastPkts                12550    OutMulticastPkts               127644
        InBadPkts                  630
      InFragments                    0
              CRC                  630          Collisions                    0
         InErrors                   84      LateCollisions                    0
      InGiantPkts                    0
      InShortPkts                    0
         InJabber                    0
     InBitsPerSec                10392       OutBitsPerSec               160280
     InPktsPerSec                    3       OutPktsPerSec                   38
4/2/1      Up      Forward Full 10G   None  No  N/A  0   609c.9f92.6231
 Port 4/2/1 Counters:
         InOctets             11070496           OutOctets            120893080
           InPkts                34259             OutPkts               234044
  InMulticastPkts                34259    OutMulticastPkts               234044
        InBadPkts                  367
      InFragments                    0
              CRC                  367          Collisions                    0
         InErrors                   42      LateCollisions                    0
      InGiantPkts                    0
      InShortPkts                    0
         InJabber                    0
     InBitsPerSec                22976       OutBitsPerSec               284928
     InPktsPerSec                    9       OutPktsPerSec                   69
4/2/3      Up      Forward Full 10G   None  No  N/A  0   609c.9f92.6233
 Port 4/2/3 Counters:
         InOctets              7730792           OutOctets              8668060
           InPkts                23077             OutPkts                26172
  InMulticastPkts                23077    OutMulticastPkts                26172
        InBadPkts                  510
      InFragments                    0
              CRC                  510          Collisions                    0
         InErrors                   60      LateCollisions                    0
      InGiantPkts                    0
      InShortPkts                    0
         InJabber                    0
     InBitsPerSec                17824       OutBitsPerSec                18800
     InPktsPerSec                    6       OutPktsPerSec                    7
BenBeck
Looks like layer 1 port flaps to me. Left most column is layer 1 (physical) transitions:
123-0-0-0(1/2/1)
31-0-0-0(1/2/3)
I only have the 4.  One of my future troubleshooting steps was to try them one at a time.  I'll try it sooner rather than later and report the results.
