Can Ruckus R610 and R720 works on same controller
faisal_khan
Hi there,
Currently we are using Ruckus R610 model Aps with Unleashed Controller version 200.8.10.3.290 now my company is planning to buy New Ruckus Aps R720 model so the existing controller will be able to detect and manage both Models.
3 REPLIES 3
sam_evans
You can refer to the release notes on the support site for the firmware you are using to see which APs are supported: https://support.ruckuswireless.com/documents?filter=82#sort=relevancy&f:@commonproducts=[Unleashed]
In your scenario the R610 and R720 will work in the same environment.
Thanks will Test it..
syamantakomer
Community Admin
Community Admin
Hi Faisal,
Yes, both APs are supported, as of 200.9 (latest version as of today).
200.8 also supports both AP models.
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
