Showing results forย
Search instead forย
Did you mean:ย
zf2925 became zf2825. Is it possible to turn back?
alexey_belichen
I purchased on eBay zf2925 but in web GUI it appeares as 2825, so it does not have VLAN functionality that I need. Is it possible get it 2925? Or it has hardware from 2825?
14 REPLIES 14
jelle_alten_606
Contributor
Is it possible to do a firmware upgrade? What software version does it run on?
alexey_belichen
The software version was 5.3.1.0.58 up to this moment. As I remember I upgraded it earlier. Now I have successfully upgraded it with local file 2925_4.2.0.0-132_Main.Bl7 that I had. Software version appears as 4.2.0.0.132 but the top line is "Ruckus 2825 Multimedia Wireless Router"
jelle_alten_606
Contributor
I can setup a little server of mine, that you can use to upgrade in steps, if you want to. My ZF2925 is all the way up to Software Version 8.1.1.0.12 now. After each upgrade I had to reboot the device to see if it was running the new version.
I'm not sure how it will respond if it thinks it is a 2825, but it might be worth a shot...
catch me on twitter for direct contact. @jellealten
