07-04-2023 03:49 AM
I use POE with part number 740-64284-001 but in my ruckus R720 in web unleashed in transmission standards is 802.3af and in watt meter just 10 watts, what poe injector must i use to get maximum watt?
07-04-2023 04:45 AM - edited 07-04-2023 04:48 AM
Hi @arMan
The accessories with R720 is as listed below. You can login to the AP CLI and execute below command to force at power mode (if the power injector or switch is capable of providing the power it will change).
set power-mode at
To confirm the changes :
get power-mode
Note : If this is Master AP you would need to follow below to move to AP CLI mode :
ruckus> en
ruckus# ap-mode
You have all rights in this mode.
ruckus(ap-mode)#
Best Regards
Vineet
07-06-2023 05:55 AM
Unfortunately we do no have the option in the GUI or the CLI to check EIRP but once full power is provided it provides max as per the country regulations.
Best Regards
Vineet
