04-12-2019 12:29 PM
rkscli: fw set port 21
OK
rkscli: fw set control r500_110_cntrl.rcks OK rkscli: fw force-update fw: Updating rcks_wlan.main ... v54_fw_update: download 192.168.1.1 section=rcks_fw.main image=Image1 ctl_file=zf7372_104_cntrl.rcks (/writable/fw/main.cntl) flash id is 0x10220 imghdr.{hdr_len=160, bin_len=10970972} fw_flash_read_open: open((null),) failed rks_flash_read_open(1) failed tail_offset 10968928 bin_len 10970972 sign 1. fwcheck is 2. net_get_flash, Upgrading from Fully Signed Image(FSI) to Intermediate Signed Image(ISI) image. Firmware size mentioned in control file(10971132) _erase_flash: offset=0x0 count=42 Erase Total 42 Units Performing Flash Erase of length 262144 at offset 0xa40000 done [====================================================================================================] 100 + read_size 8192; rc=2044 net_get_flash: Receive last block buf 2044 net_get_flash: hdr_fsize=10969088, real_fsize=10969088 net_buf 0x7ffe3914 Reading Image TAIL:- TLV No-1.TLV INFO Number of TLVS in Tail is 2. Size of Tail is 2044. len 9 tail_len = 9 2. SIGNATURE OBTAINED SUCCESSFULLY len 259 tail_len = 268 cert len 1773 pass 3. CERTICATE OBTAINED SUCCESSFULLY len 1776 tail_len = 2044 1444: rc1 2044 tail_len 2044 MD5 Checksum successful!!!!!!!!! Checking Image hash:- 1. Obtaining public key from Certificate. Executing openssl x509 -in /tmp/in_cert.pem -pubkey -noout >/tmp/pubkey.pem line: Certificate will not expire Certificate validity verified. line: /tmp/in_cert.pem: OK 2. Public key verified. 3. Decrypting the Image signature. Executing openssl rsautl -verify -pubin -inkey /tmp/pubkey.pem -in /tmp/signsure.bin -out /tmp/ext_sha256. 4. Comparing the signatures:- IMAGE TAIL SHA256 : 0a359971c5e62baa9e82a6aac681e922fca8a3ed6b8efb45b35333292781bd45 CALC SHA256 : 0a359971c5e62baa9e82a6aac681e922fca8a3ed6b8efb45b35333292781bd45 HASH CHECK PASSED. AIS cleanup : Removing /tmp/ext_sha256... AIS cleanup : Removing /tmp/in_cert.pem... AIS cleanup : Removing /tmp/signsure.bin... AIS cleanup : Removing /tmp/pubkey.pem... AIS cleanup : Completed bdSave: sizeof(bd)=0x7c, sizeof(rbd)=0xd0 caching flash data from /dev/mtd3 [ 0x00000000 - 0x00010000 ] updating flash data [0x00008000 - 0x000080d0] from [0x7ffea158 - 0x7ffea228] _erase_flash: offset=0x0 count=1 Erase Total 1 Units Performing Flash Erase of length 262144 at offset 0x0 done caching flash data from /dev/mtd3 [ 0x00000000 - 0x00010000 ] verifying flash data [0x00008000 - 0x000080d0] from [0x7ffea158 - 0x7ffea228] **fw(1726) : Completed rkscli: reboot OK rkscli: exit Quit: OK Connection to 192.168.43.168 closed.
04-12-2019 01:01 PM
fw set host 172.17.1.1The below Procedure would require Support's assistance and which should not consume more than 5 mins wait time, I have used it most of the time to do a quick test.
fw set control rcks_fw.bl7 <110.x version firmware>
fw set proto tftp
fw update
rm -f /tmp/wsgclient/isManagingThe above command would enable you to upgrade the Firmware via http/https, and please use 110.x firmware, using any other version gives you error once it is on 110.x firmware then you can update the AP to older versions.
fw show all
04-12-2019 01:56 PM
04-12-2019 05:53 PM
05-12-2019 01:15 PM
