ukus h510 after upgrading firmware to unleashed am not able to remove access point previously configured it is still enable and
Hi i have Rukus h510 after upgrading firmware to unleashed am not able to remove access point previously configured it is still enable and
10 REPLIES 10
thanks this doc was very useful too.
Hi thanks again for your quick response.
After factory reset i install the only the unleashed firmware will it be working solo  standalone access point?
Hi 10 sec on hard reset . it reset only the configuration of the unleashed,
Yes, Since it is upgraded to Unleash firmware, it will just reset the configuration by pressing the reset button. Firmware will remain the same.
-Ankush
Hi Ankush,
Sorry for disturb.
I found The issue, it was not with the H510 .
I checked in rogue devices found its was another device configured with the same SSID same password.
Found the device disconnected it, everything is fine.
I should have checked in the rogue devices first.
Thanks a lots for your assistance. looking forward to work with you again.
Regards John.
