r700 convert stand alone mode
Hi, I want to buy  2 pieces 901-7982-ww00 model AP . They have a firmware  to be used with controller.  I want to use them stand alone. which version should i upgrade?
3 REPLIES 3
jay_files
Contributor
jay_files
Contributor
Oops, the part number you mentioned, 901-7982-ww00, is 7982, not R700.
The solo firmware for 7982 is here: https://support.ruckuswireless.com/products/38-zoneflex-7982#firmwares
Esteemed Contributor II
But the ZoneFlex 7982 model AP has been End of Sale since Dec 31, 2016, so you will have to look for "used".
Please check the serial number of the APs with Ruckus support, BEFORE you buy them on a 2nd hand market,
to be sure they are NOT rejects that other customers have received a valid RMA replacement for.
Those APs were supposed to have been sent back or destroyed, and will NOT be replaced by Ruckus again, if you find problems.
Version 104.0.0.1347 is the last Solo AP image for zf7982 models, free to download* (with at least an email associated Guest account on Support).
https://support.ruckuswireless.com/software/1017-zoneflex-solo-access-point-104-0-0-0-1347-ga-softwa...
