r510 setup
paul_milcheck
try to configure an r510 new out of the box.
I can ping unit at default address but browser will not connect due to ssl errors tried chrome ff edge and ie11
no go
any ideas?
5 REPLIES 5
vijaykuniyal
RUCKUS Team Member
Hi @paul_milcheck,
If you are getting a cert error, you can click on Advance and then Accept the risk and continue, you will be able to see the login page.
If still doesn't work, try to ssh into the AP using Putty or any other ssh tool, check the output of below commands.
rkscli: get https
HTTPs access is enabled
rkscli: get http
HTTP access is disabled.
if https still doesn't work, enable http on the AP with the command "set http enable" and test in the browser.
Vijay Kuniyal
Staff Technical Support Engineer
CCNA RnS | CCNA Wireless | CWNA | RASZA | Meraki CMNO | RACPA
sanjay_kumar
RUCKUS Team Member
Hi @paul_milcheck
The error you see is because the AP has default SSL cert.
If you click on Accept and Continue, then you should be good.
Follow the steps provided by Vijay Kuniyal as below and let us know if you face any issues.
paul_milcheck
Am able to get further thanks to rebooting the device ,but now am stuck at :Building the Unleashed Network. It may take a few minutes.
Hi @paul_milcheck
Looks like the AP is trying to see if there is any other Master in the network before it elects itself as Master. If the AP is stuck in that mode for too long, try rebooting or resetting the AP.
