r300 doesn't connect to ZD1100
My R300 does not connect to ZD1100.
I can connect to de r300 when directly is connect to my computer and also can login but do not know what to do next.
I'd follow the quick step manual for configure the r300.
The landcode is US and i live in the Netherlands.
The ZD1100 firmware is 9.10.0.0
10 REPLIES 10
martin_martin
Valued Contributor
Sander you are not allowed to use the US country code in The Netherlands as every country has their specific frequency rules.
On the AP itself, please login to the AP with the default username and password and and type "get version" and print that here.
Also provide the full version builds that the ZD has.
Regards
Martin
AP has 3.2.1.0.659
ZD has 9.10.0.0 build 218
Your AP appear to ha SmartZone Firmware. Try to load standalone firmware on the AP and then give it a go. If you cannot login to the AP try a factory reset to remove any smart zone passwords.
Do i have take the newest firmware of do i have to upgrade from old to new?
martin_martin
Valued Contributor
Hi Sander,
So you have SZ/SCG/vSZ software on the AP instead of ZD software.
You can do the following
login to the AP and set to factory default with the set factory command.
Then login to the AP via webgui and use the upgrade option (then choose local file) to upload this file
https://support.ruckuswireless.com/software/1017-zoneflex-solo-access-point-104-0-0-0-1347-ga-softwa...
After that it will reboot and will have the 104.0.0.0.1347 software, and you can use the set director to let it find the zonedirector.
Please download the file shortly as it only stays up for 1 week.
Kind regards
Martin
