03-28-2021 06:08 AM
hi everyone,
i have outdoorT610, was working fine so when I left company for some days off, the operations team have accident when them trying cut the tree...the tree dropped to device T610, device is looking fine. so there problem with t AP is working after 15 min the system is freezing.
i had to remove from ZD 1200,change firmware with standalone unleashed , hardreset, and
the issues still persist.
please someone help with other idea or support
03-29-2021 01:46 PM
If there was some hardware damage happened to the device, I don't think there is any way to fix it, except replace it.
If you have support on the AP, please open a case and request for the replacement. Support will also be able to check if issue is not related to the hardware but something else.
