multiple R310 APs for 1 network
Hi, I would like to know if it is possible to use 4 R310 APs (in different rooms) to create 1 SSID for office employees to access the entire network and 1 SSID for guests for Internet access only. Do I need an additional ZoneDirector for this? Where can I find installation manuals for the R310? Thanks! Frank
10 REPLIES 10
beat_schilliger
Hi Frank, I operate two R310 in an unleashed network at home. I've got two SSIDs: One in the intranet, one in the DMZ with one-time-passwords (valid for one day) for guests or/and unsafe devices (Smart-TV, Smartmeters etc.). It works as describe - no problems!
https://www.ruckuswireless.com/products/system-management-control/unleashed
Thanks! Sounds like this should work. You also have 1 SSD for your intranet?  Should you install the first AP as master and the others as backup?
beat_schilliger
SSID 1: Intranet in VLAN x
SSID 2: DMZ in VLAN y
AP 1: Master
AP 2: no special configuration
Image_ images_messages_5f91c430135b77e2479aaf44_e3479bc46e707a79ba12bb218379eaa3_RackMultipart2017020347552mbk0-ba680b69-3d59-4fcb-839b-ef2c46dc6c61-1640368749.png1486130348
How do you configurate the VLan
